https://auszookers.com/forum/
F10A Big End Bearings.
https://auszookers.com/forum/viewtopic.php?f=5&t=7734
Author:  Rito [ Wed Nov 04, 2009 10:51 pm ]
Post subject:  F10A Big End Bearings.
Just got some new bearings in the mail only they are a bit bigger than the originals..
Old Ones
ID- 39ish mm
1.45ish mm thick
17.77 mm wide
ACL 8341 15AP03
New Ones
ID- 50.8ish mm
2.05ish mm thick
20mm wide
ACL 5M8342-.25 To suit F10A, F8A
Different year models????
Author:  losfer [ Thu Nov 05, 2009 12:07 am ]
Post subject:  Re: F10A Big End Bearings.
see the 5M in the part number .. it means 5 Main bearings
big end part number will read 4B 8341 -.25 (if you need .25 bearings ...)
Author:  Rito [ Thu Nov 05, 2009 12:44 am ]
MMMM Bugger, Oh well looks like Im doing the mains as well. Cheers
Author:  losfer [ Thu Nov 05, 2009 12:49 am ]
you realise thats an engine out job ? , unlike the big ends which can be done in-car ?
have you reground the crank ? or was it like that when you pulled it apart ?
it would pay to go buy some plastigauge and check all the clearances with the new bearings before assembling .
