It is currently Sun Oct 18, 2026 7:07 pm
Post Posted: Wed Nov 11, 2009 7:18 pm
Ok so this afternnon I took a drive down to a localy recomended engineer and picked his brain about my zook and a few other things.
Here are the questions I asked.
Q1 What is the max suspention lift?
A. In N.S.W. on a "standard" Suzuki Sierra no more then 6" total this can be made up of a few different things like springs, SPOA, shackles or RUF But no more then 6" on standard Diffs and Standard frame.
Non standard (different diffs, frame mods.....) will be on a case to case baises.
Q2 What are limitations on body lifts?
A. All body lifts are looked down on. They dont like to do them. But 2" is normaly ok if they are done right.
Q3 What is the biggest tire I can run ?
A. 31s pass everytime regardless. ANYTHING bigger will need bigger diffs. He said he has passed 35s on a LWB that had landcruiser 60s diffs under it. 33s are the biggest he would pass on hiluxs diffs.
But to add to that the diffs would have to pass inspection first.
Q4 When doing any engine swop what will make it pass?
A. He said all engine swops are on a case to case basis. The more common the swop the easier it will be to pass it. But what they look for is.
#1 is all the eco stuff on it (cat, 02 sensors .....)
#2 It is mounted as stong or stronger then what that motor is in its factory application.
#3 It is a safe upgrade in power (meaning its not a V8 in a mini kind of deal. Anything that is over double the power is seen as overkill and will be hard to pass.
#4 All the wiring is done correctly and safely.
#5 That all addaptor plates or convertions are done in a safe or stronger then factory way.
#6 It must pass a sound and exhaust test for that year model of engine
#7 It can not be leaking any fluids.
Q5 What are the costs to get a inspection done.
A. It all depends on time spent. Most engine swop/susspention inspections are around the $750 to $900 mark
Hope that helps some you out.
Post Posted: Wed Nov 11, 2009 7:25 pm
will yours pass engineering?
Vehicle: MY2019 Jimny
Who did you see?
Post Posted: Wed Nov 11, 2009 7:26 pm
No not as it is. I have to loose the wheels and loose the shackles. My engine will pass if I put the standard airbox back on it. everything else is ok.
Post Posted: Wed Nov 11, 2009 7:27 pm
Engineering for engine conversion here in QLD is $150 + $50 for additional mods, eg seats, brakes. Contact me for details if you wish.
Post Posted: Wed Nov 11, 2009 7:39 pm
That almost makes it worth the drive... Would a QLD cert pass in N.S.W.????
Post Posted: Wed Nov 11, 2009 7:58 pm
No because we are not QLD...
Post Posted: Wed Nov 11, 2009 8:07 pm
a mod plate is not engineering.
Post Posted: Wed Nov 11, 2009 8:39 pm
qld has pretty specific rules on what engine can be passed in what car for a mod plate though, after that it gets dear
Post Posted: Wed Nov 11, 2009 8:42 pm
To clearify when I said mod plate i was talking about the addapter plate used to mount the engine to the trans.
Post Posted: Wed Nov 11, 2009 10:02 pm
SPOA is fine but they don't like body lifts. When body lifts are a very easy mod that don't effect to much in comparasion to SPOA with steering changes, induced stresses etc etc etc. Seems strange. It's very easy to do some mods very wrong yet others are less likely to be approved.
Post Posted: Wed Nov 11, 2009 10:27 pm
yep. its all fucked.
Don't worry, It's only a suzi...
http://www.auszo
Post Posted: Wed Nov 11, 2009 10:39 pm
Now go ask a different engineer those same questions, then another.
I'll guarentee you'll get different answers each time
You'll soon realise why all the shit that has been going on in NSW has raised it's ugly head.
He sounds like one of the "easier engineers"
Post Posted: Wed Nov 11, 2009 11:22 pm
X2
Athol Mullen a good engineer (possiable one of the best in aus) He passed my truck with 31s, 50mm BL and 50mm suspension about a year ago. $250 for the first item and $50 for everything after that. I paid $350 for my truck to be passed.
Im not sure that ge will pass the 31s anymore...
Post Posted: Wed Nov 11, 2009 11:29 pm
He said 31s would be ok with a zook a few months back...
I agree, I have not heard a bad thing about him.
Post Posted: Wed Nov 11, 2009 11:32 pm
I avn't been in contact with him for a while... twas just what i heard... He will only pass 33s on lux diffs, now i know that for a fact :D
Post Posted: Thu Nov 12, 2009 12:00 am
What tests do they do to approve bigger tyres?
Post Posted: Fri Nov 13, 2009 2:53 am
Brake test is the big one. But other then that I have no idea...
Post Posted: Fri Nov 13, 2009 2:57 am
Ohhh and the tread cant stick out over 10mm
Post Posted: Fri Nov 13, 2009 4:21 am
Wouldn't pass mine with 31s but did do spoa bl seats wrap bar etc etc
Post Posted: Fri Nov 13, 2009 4:53 am
Who did you go to?
Post Posted: Fri Nov 13, 2009 11:03 pm
Athol did mine. Was just after the new rules were stopped
Post Posted: Sat Nov 14, 2009 2:52 am
Im sure there is good reason behind all of his claims and rules... :D
Post Posted: Tue Nov 17, 2009 8:46 pm
[quote="v.w.dave"] 31s pass everytime regardless.
I just called a local engineer in vic and the max increase approved is 2 inches bigger than stock. Stocks are 26 inches so that puts my 30's already over and out unless i upgrade axels etc.
Is all of vic like this ?? because that sucks
Wish i was in NSW
If not who should i call
Post Posted: Tue Nov 17, 2009 10:31 pm
Think your self lucky, In qld we can only increase 15mm over standard.
Post Posted: Tue Nov 17, 2009 11:04 pm
we can do a 100mm lift with no engineering or mod plates. :D
Users browsing this forum: No registered users and 455 guests
