It is currently Sun Oct 18, 2026 3:10 pm
Post Posted: Fri Nov 13, 2009 10:50 pm
I'm in the process of replacing my suspension and have discovered a bent shackle. Without spending a fortune, should I just replace them it with an oem shackle or are there any heavy duty shackles available which are a direct replacement but beefier?
Cheers,
Jimmy.
Vehicle: 75 Cruiser
Post Posted: Fri Nov 13, 2009 10:54 pm
Got a pic of the bent shackle?
Do you really need heavy duty shackles?
I guess most people might advise you to get extended shackles instead, but if you don't really need them i wouldn't. I'd just replace the stocker ones, because how often do you bend shackles?
Post Posted: Fri Nov 13, 2009 11:25 pm
I don't want extended shackles. What site would you recommend for picking up a couple of new standard shackles?
Here's the bent one:
Vehicle: 75 Cruiser
Post Posted: Fri Nov 13, 2009 11:40 pm
they look ok to me, but i have low standards.
they sll them here http://suzistore.com.au/shopdisplayproducts.asp?page=3
but $30 might be a bit expensive, i've seen them on ebay but not sure of the quality.
Post Posted: Fri Nov 13, 2009 11:44 pm
Shit, same as the one's Lance used to sell, slightly narrower & the bolt's on the fixed side walk out, but i was rather hard on them. :roll:
Vehicle: 75 Cruiser
Post Posted: Fri Nov 13, 2009 11:49 pm
oops, just to clarify, the suzistore ones look really good, but i have seen different ones on ebay, which i am not sure about.
Post Posted: Sat Nov 14, 2009 12:02 am
I knew what you meant. :? 8O :P
Post Posted: Sat Nov 14, 2009 5:02 am
Someone will have some lying around, right Steve.
Post Posted: Tue Nov 17, 2009 3:27 am
ouchieee how'd you magage??
Heeyy Haterzzz :lol:
I Love AZ!!! and the controv
Users browsing this forum: Google [Bot] and 364 guests
