| front diff leaking? https://auszookers.com/forum/viewtopic.php?f=5&t=7978 |
| Author: | boost=money [ Sun Nov 15, 2009 3:03 pm ] |
| Post subject: | front diff leaking? |
my front diff has been leaking oil for a while so i redid it all, then drove about 3km and its leaking again? the iner seal the small black one is the one that leaks, the old seal wore on both side but the top and bottom where fine. so dont think it is the housing bent, what would cause this the brash bush looking thing under the stub axel worn out mayb? |
| Author: | steak_knife [ Sun Nov 15, 2009 9:51 pm ] |
| Post subject: | Re: front diff leaking? |
boost=money wrote: my front diff has been leaking oil for a while so i redid it all, then drove about 3km and its leaking again? the iner seal the small black one is the one that leaks, the old seal wore on both side but the top and bottom where fine. so dont think it is the housing bent, what would cause this the brash bush looking thing under the stub axel worn out mayb?
Or one of the seal's are not seated properly. Axle was in good nic were the seal run's? no grove's in it? |
| Author: | zooker [ Mon Nov 16, 2009 12:14 am ] |
Did you use genuine suzuki seals? I used the ebay ones and one started leaking within a week. Replaced with genuine ones and been good for ages |
| Author: | boost=money [ Mon Nov 16, 2009 1:58 am ] |
the shaft looks fine and the seals r from bersons, it is wereing the seal out on the front and back not the top or bottom like a bent housing, any idea what could cause this? |
| Author: | boost=money [ Mon Nov 16, 2009 10:26 pm ] |
can u buy new stub axels? and whats the go with the brass bush thing behind it? it looks like a bit of brass hammered in there but both the diffs i had had this, just chasing ideas on what to change first im sick of oil pouring out every where. cheers |
| Author: | steak_knife [ Tue Nov 17, 2009 12:19 am ] |
boost=money wrote: can u buy new stub axels? and whats the go with the brass bush thing behind it? it looks like a bit of brass hammered in there but both the diffs i had had this, just chasing ideas on what to change first im sick of oil pouring out every where. cheers
Meant to look pitted, hold's grease in where it's needed. Mate, it really dose sound like a bent housing. Didn't you just do a W/t conversion? |
| Author: | boost=money [ Tue Nov 17, 2009 1:42 am ] |
yeh i did just do one about 6weeks ago it has leaked ever since so i changed all seals and bearings again then drove about 2km the most and it was leaking? it leaks both sides. |
| Author: | steak_knife [ Tue Nov 17, 2009 1:47 am ] |
boost=money wrote: yeh i did just do one about 6weeks ago it has leaked ever since so i changed all seals and bearings again then drove about 2km the most and it was leaking? it leaks both sides.
In think you may be bent, or you housing is any way. |
| Author: | boost=money [ Tue Nov 17, 2009 1:49 am ] |
how do i cheack this? string line or something? |
| Author: | steak_knife [ Tue Nov 17, 2009 1:53 am ] |
boost=money wrote: how do i cheack this? string line or something?
That'll work, look for dint's to, like accident damage, could of had a hit in the front.( the car the diff's come out of) Sound's like it's bent front to back not up & down. |
| Author: | boost=money [ Tue Nov 17, 2009 2:08 am ] |
ok thanks for your help i will try mesuring it up then get back to u cheers |
| Author: | boost=money [ Wed Nov 18, 2009 10:08 am ] |
did the best i could to mesure the diff up seems straight, can u buynew stub axels or can the brass bit b replaced? |
| Author: | steak_knife [ Thu Nov 19, 2009 1:43 am ] |
boost=money wrote: did the best i could to mesure the diff up seems straight, can u buynew stub axels or can the brass bit b replaced?
Try suzistore, not sure if you can get new tho. |
