It is currently Sun Oct 18, 2026 5:07 pm
Post Posted: Tue Nov 17, 2009 2:11 am
Are the g13a and g16a sump and oil pick up's the same i have a g16a sump and oil pick up and want to put it on the 1.3 i got.
cheers.
Post Posted: Tue Nov 17, 2009 2:36 am
nope
Post Posted: Tue Nov 17, 2009 2:42 am
whats the difference do you know?
will it fit?
Post Posted: Tue Nov 17, 2009 2:51 am
sump will bolt on but then (unless you have a lot of lift) your diff will beat the shit out of it. :D
Post Posted: Tue Nov 17, 2009 3:01 am
ok well that sucks thanks for your help mate
Post Posted: Tue Nov 17, 2009 3:09 am
Maybe your just to rough shep! :rofl: :rofl: :rofl: :finger:
Post Posted: Tue Nov 17, 2009 3:15 am
very possible :lol:
Post Posted: Tue Nov 17, 2009 3:18 am
cheers.
I can show what need's doing or do it for you, you need to make one pickup out of both the G13 and the G16 pickups
And then you need to modify the internal baffel on the G13 sump to clear the G16 main cap Gerdel's :wink:
Post Posted: Tue Nov 17, 2009 3:20 am
i think he wants to put the 1.6 stuff on a 1.3
oops i read the question backwards....
Why do you want to fit a G16 Sump and pickup to a G13 engine?
Seems pointless IMO :?
Post Posted: Tue Nov 17, 2009 5:01 am
will the diff still hit if you hilux diffs instead of w/t
Post Posted: Tue Nov 17, 2009 7:38 am
Probably since the front diff is offset the same way, the 1600 sump is made to suit an IFS vitara not a live axle sierra
Post Posted: Tue Nov 17, 2009 12:42 pm
my SWB has a g16 with the standard sump and i have had no problems.however
it has 100mm spring lift and the diff has been moved around 50mm forward.
Post Posted: Tue Nov 17, 2009 12:44 pm
so when i put my g16a in and spoa hilux diffs it should be fine then?
Post Posted: Tue Nov 17, 2009 12:57 pm
dunno mine is on propper diffs :D
i think our tassie mate zookernater has the standard g16 sump and hilux diffs.
Post Posted: Tue Nov 17, 2009 1:41 pm
You will also need to modify the oil pickup as the mounting points are different as well as the location for the oil pickup (lowest point in sump)
Post Posted: Tue Nov 17, 2009 4:12 pm
I don't have a sump
on the engine I got off Steve but have a 1.6 one so I thought I could use the 1.6 but I'll use the one on my 1.3 bwhen I remove it
Users browsing this forum: No registered users and 277 guests
