https://auszookers.com/forum/
engine work
https://auszookers.com/forum/viewtopic.php?f=5&t=8025
Author:  BUZOOKA [ Tue Nov 17, 2009 2:26 pm ]
Post subject:  engine work
im rebuildinh my motor some time in the next couple of months and have decided to boar(spelling) the engine out about 40thou my brothers idea just to get some extra out of the little motor just wondering if anyone else has done it and how much more power/ torque did u get ??
CHEERS ZOOKA
Author:  BlueSuzy [ Tue Nov 17, 2009 2:31 pm ]
Post subject:  Re: engine work
BUZOOKA wrote:
I'm rebuilding my motor some time in the next couple of months and have decided to bore the cylinders out about 40thou. Its my brothers idea as i just want to get some extra out of the little pip squeak motor. I am just wondering if anyone else has done it and how much more power did u get ??
CHEERS ZOOKA
I wouldn't bother. Just hone the cylinders and rebuild.
Otherwise. 1.6efi. :)
Author:  Rusho [ Tue Nov 17, 2009 2:41 pm ]
CHEERS ZOOKA
x2 Any work you do will be almost a waste of good $$ as it will probably go unnoticed on such a tiny mill. Just my opinion. Others might disagree. A cam and carby work might make a small difference.
Author:  BUZOOKA [ Tue Nov 17, 2009 2:45 pm ]
not wasting more money than i have to with buying a 1.6 means i gotta buy the motor then rebuild it if anythings wrong with it plus spend all my time tring to figure out the wires when i can just rebuild my motor and put a bit more grunt in to it
Author:  BlueSuzy [ Tue Nov 17, 2009 2:47 pm ]
Hire a constant tailwind. That will give you more power.
Author:  BUZOOKA [ Tue Nov 17, 2009 2:50 pm ]
this is tech chat plz keep ur sarcasm for the chat section plz :roll:
Author:  royce [ Tue Nov 17, 2009 2:55 pm ]
overboreing does little to increase power but if your pistons are worn and your bore is out of round (will be) then its an essential recon step
get a cam and up the compression a bit for more go
Author:  BUZOOKA [ Tue Nov 17, 2009 3:05 pm ]
thanks royce instead of trying to push me t the 1.6 u actually gave me some advice thanks
Author:  gypsy [ Tue Nov 17, 2009 3:12 pm ]
mine is 40 over mild cam and rejet goes realy well worth the money
Author:  BlueSuzy [ Tue Nov 17, 2009 3:14 pm ]
I gave you tech. Your not reading.
Author:  BUZOOKA [ Tue Nov 17, 2009 3:30 pm ]
wats that on the tail wind i just need an inverter anda hairdryer for that :lol:
Author:  royce [ Tue Nov 17, 2009 4:47 pm ]
for ther cost of a rebuild on a 1.3 its not really worth it IF you can get a good efi engine, more power and will alst longer nayway
Author:  BUZOOKA [ Tue Nov 17, 2009 4:59 pm ]
thats the thing theres a big IF there
Author:  royce [ Tue Nov 17, 2009 5:08 pm ]
even Jimny motors arent to dear
Author:  bakerboy [ Tue Nov 17, 2009 5:47 pm ]
damaged vehicle auctions are where its at mate, can pick up a complete car with the 1.3 or 1.6 with computer etc between 500-700 bucks, then part the rest off and make some $
