It is currently Thu Oct 22, 2026 2:05 pm
Post Posted: Sat Nov 21, 2009 8:07 pm
The wife's 95 LWB Vitara driver's door needs to be moved back about 5mm, so it shuts properly. At the moment, the wind noise is bloody annoying at speed, but the passenger door is fine. After some comparisons, I noticed the incorrect alignment of the driver's door.
So, I'm assuming I'll need to adjust the hinge placement on the body, but I'll need to remove the guard to get to the bolts. There's 4 or 5 bolts along the top of the guard near the engine bay, but I can't see where any other botls might be. Anyone able to advise?
Regards,
Ranga
Post Posted: Sat Nov 21, 2009 8:17 pm
5 along the the top of the gaurd
one up infront of the rear veiw mirror ( can see when opening door) and another opposite (can see from under bonnet) to that on the same peice.
there are two down at the bottom of the gaurd under the plastic trim where it bolts to the sill.
there is a screw underneath where the grill screws in (better to carefully remove grill, which means removing bumper)
and you will need to take the clips out of the inner gaurd.
OR if you take the inner gaurd plastic sheild thing out you could easy get to the door hinge bolts :)
sam
Post Posted: Sat Nov 21, 2009 8:36 pm
so yeah just remove inner guard liner don't worry about the guard.
sam
Post Posted: Sun Nov 22, 2009 5:54 am
awsome ... might fix my drivers door tomorrow :D
Post Posted: Sun Nov 22, 2009 11:47 am
thanks sam, my door is sagging to so i will have to try that :D
Post Posted: Sun Nov 22, 2009 1:00 pm
sam
Thanks mate :wink:
Regards,
Ranga
Post Posted: Sun Nov 22, 2009 2:18 pm
I'll come over & do it for the alloy Gv wheel's :P :P
Post Posted: Mon Nov 23, 2009 2:55 am
Adjusted the door today, hoping to get rid of the wind noise. A little bit tricker than I had hoped. Ti get to the top hinge, it really did make it easier to remove the top screws and move the guard away from the body.
Anyway, I think the rubbers have retained their shape from the old position, as they now permanently sit a mm or so away from the window arch. I think the only way I'm going to fix this is new door rubbers. Any idea how much they are?
Regards,
Ranga
Post Posted: Tue Nov 24, 2009 6:32 pm
is your door frame bent ?
i had to take a bend out of the door frame and also adjust in the latch to get doors to seal on a swb vit.
Post Posted: Wed Nov 25, 2009 2:17 am
Maybe it is - a panel beater offered to "massage" it back into place.
Could it also be the hinge bolts on the door side, as opposed to the body side? I was wondering if I loosened the top 2 bolts and one of the bottom bolts, maybe the door might adjust in a bit?
Regards,
Ranga
Users browsing this forum: Google [Bot] and 94 guests
