It is currently Fri Oct 23, 2026 7:27 pm
Post Posted: Tue Dec 01, 2009 2:54 am
i want to make a custom steel snorkel, just wondering what diameter pipe i should use, i am thinkin 3" also does anyone have pictures of thier custom snorkels, especially pictures of how you connected to the airbox. chers guys
Post Posted: Tue Dec 01, 2009 3:03 am
even 2and a half would be plenty i would think
Post Posted: Tue Dec 01, 2009 3:21 am
3" looks good, and it makes buying snorkle heads a little easier too.
Post Posted: Tue Dec 01, 2009 3:29 am
i made mine the same size as the inlet on the air box and used a dobson pre cleaner.
Post Posted: Tue Dec 01, 2009 3:38 am
i want the top to curve back, like the comp trucks so snorkel heads dont bother me. i also want the outer part of the snorkel to be all steel, no silcone joiners, just need to figure out how to meet the pipe to the aircleaner, can you buy a reducer from 3" to what ever diameter the fitting on the aircleaner is
Post Posted: Tue Dec 01, 2009 4:06 am
i used a radiator hose from a bulldozer to join the snorkel to the airbox. :wink:
Vehicle: WR250F/Jeep XJ
Post Posted: Tue Dec 01, 2009 2:13 pm
I used 3" aluminium pipe with rubber bends I got from a truck bits store. The pipe was free from a local aluminium suppliers offcuts bin which they let me have a look through.
I used s 3 to 2" reducer to connect up to the airbox.
Post Posted: Tue Dec 01, 2009 7:07 pm
This is what I did. Took a bit of farting around but came out ok.
Post Posted: Tue Dec 01, 2009 8:43 pm
3 inch only looks good when you have mammoth tyres like dank
Post Posted: Tue Dec 01, 2009 9:12 pm
2.5inch looks best imo...
i made mine from scrap stainless pipe!
Post Posted: Wed Dec 02, 2009 12:24 am
3' ms zorst, 180 mendrel bend, 3' to 2' 90 silicon bend..powdercoated black
Post Posted: Wed Dec 02, 2009 2:52 am
i like that last one, it follows the lines nicely. it really needs a bend in the top so the head sits level.
Post Posted: Wed Dec 02, 2009 11:07 am
I know...the plan is to get one of those flash looking newer style heads you see getting round on the TJM kits etc. It will blend in just nicely then.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 125 guests
