It is currently Fri Oct 23, 2026 12:56 am
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Wed Dec 09, 2009 6:24 am
Hey Guys....
I've looked in the Vitara Manuals that I have an I can't seem to locate the Gear Ratios for the 5spd Manual ('93 model LWB)
I'm after the ratios for 1st / 2nd / 3rd / 4th / 5th & Rev PLUS the LOW RANGE Ratio of the Transfer Case as well
Can someone point me in the right direction or if u have the info post it for us :wink:
cheers.....
rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Wed Dec 09, 2009 11:51 am
Have a look in here.
http://www.suzukiinfo.com/
Post Posted: Wed Dec 09, 2009 1:20 pm
All 5-Speeds are the same ratio.
Manual Transmission
Type Five-speed, all synchromesh
Clutch Dry, single disc, diaphragm spring
Gear ratios
1st 3.65
2nd 1.95
3rd 1.38
4th 1.00
5th 0.86
Reverse 3.67
Transfer gear ratios
Low (4WD) 1.82
High 1.00
Differential ratio 5.12
Automatic Transmission (optional)
Type Three-speed automatic
Torque Converter Lock-up
Gear ratios
1st 2.40
2nd 1.47
3rd 1.00
4th NA
Reverse 2.00
Low (4WD) 1.82
High 1.00
Differential ratio 4.62
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Wed Dec 09, 2009 6:14 pm
Thanks for that guys....
I've done up a excel spreadsheet to help work out what speeds u could expect for a certain gear ratio vs diff ratio vs low range ratio.... for those of you who may be interested.......
Users browsing this forum: AdsBot [Google] and 183 guests
