| vitara timing belt - should i get the belt or kit? https://auszookers.com/forum/viewtopic.php?f=5&t=8529 |
| Author: | theroadrunner [ Wed Dec 09, 2009 9:42 pm ] |
| Post subject: | vitara timing belt - should i get the belt or kit? |
I need to replace the timing belt on my 92 vitara should i get a timing belt or a timing belt kit to put on it and are they easy to do or should i get a mechanic to do it |
| Author: | royce [ Wed Dec 09, 2009 9:46 pm ] |
| Post subject: | Re: vitara timing belt |
do both the seals do the bearing if it looks dodgy its not hard but fiddly |
| Author: | sp1086 [ Thu Dec 10, 2009 1:30 am ] |
Get the Kit.. You Get the belt, 2 seals & the tensioner bearing. Its just better to be safe than sorry. If that bearing goes another 20k down the road you'll be kciking your self for not changing it. |
| Author: | losfer [ Thu Dec 10, 2009 2:39 am ] |
might as well do the water pump while you're in there ... |
| Author: | Scrawny [ Thu Dec 10, 2009 12:03 pm ] |
| Post subject: | Re: vitara timing belt - should i get the belt or kit? |
I've always thought those kits were waaaay over priced. But in saying that, I still do the lot while I'm in there. They're not a hard belt in comparison to other makes but it's a waste of time just doing the belt. Once it's all done you have peace of mind for 100.000kms. Replace the drive belts too, you gotta take them off so might as well replace them. |
