It is currently Thu Oct 22, 2026 11:56 pm
Post Posted: Wed Dec 16, 2009 11:32 pm
i have a question may sound abit dumb but sometimes when i lock my front hubs and put it in 4wd it doesn't go in ( whats the porblem?) also is it possible that only one wheel lock and nor both?
thanks
Post Posted: Wed Dec 16, 2009 11:51 pm
thanks
The 4wd stick doesn't go in?
Could be the selector bush under the 4wd stick..
Or all 4 wheel's are not engaged?
You may have a seized locking hub. ( only take's one & the front won't work)
Vehicle: SJ80, SE416
Post Posted: Wed Dec 16, 2009 11:56 pm
thanks
Sometimes the transmission might be a bit tight. You might need to drive back or forwards a short distance for the gears to mesh properly.
Post Posted: Thu Dec 17, 2009 12:00 am
it goes into gear but a couple of times im still only in 2wd
Vehicle: 98 Maruti
Post Posted: Thu Dec 17, 2009 12:03 am
it probably seized like steknig said
iv had the spring inside un clip all i needed to do was pull them apart and re set it
Post Posted: Thu Dec 17, 2009 12:07 am
Sounds like the hubs are not locking in pull them apart clean then grease.........then put back on then go wheeling 8)
Post Posted: Thu Dec 17, 2009 12:14 am
To test the hubs, put hubs in free, jack up one side at a time so the wheel is in the air, turn that hub to lock and spin the wheel. You should hear a click as it engages/disengages. Also, if 4x4 is engaged that wheel should not spin at all.
Post Posted: Thu Dec 17, 2009 12:19 am
ok ill give it a go cheers
Post Posted: Thu Dec 17, 2009 12:41 am
Or just hit hubs with a rock. Worked for me until i got around to stripping em and regreasing em.
Post Posted: Thu Dec 17, 2009 12:52 am
:lol: i had to do this to my old sierra a few years ago........they locked in then they wouldnt unlock :roll:
Users browsing this forum: No registered users and 171 guests
