It is currently Sun Oct 25, 2026 12:32 am
Post Posted: Sat Jan 02, 2010 8:01 pm
Heading down to supercheap auto for their new years sale :)
Trying to change clutch myself.
Should a just use the basic stand on front and rear.
Or can you use front and rear axel stands?
And can i se a normal wheel jack to get the stands in or do i need a trolley jack?
Sorry for all the questions :P
Any help getting this thing raised on a decent setup would be appreciated.
Post Posted: Sat Jan 02, 2010 8:45 pm
I just came back from there myself with my wallet $400 lighter (I've had pretty good success with their gold tool range, so bought the large socket set and spanner sets they have - bloody good value with 20% off). :)
I've used supercheap pin type axle stands for ages now and have never had an issue with them. More then strong enough to hold up a little Vitara. They are pretty much the perfect width for the chassis rails to sit in them which is what I usually do. I prefer to throw em under the chassis rails rather then the axles, car is much more solid as its not sitting on its suspension then.
You probably could use the stock jack to get it up there, but with 20% off I would be inclined to pick up either a bottle or trolley jack just because they are so much damn quicker/easier.
You can get a pair of the 750kg rated car ramps for like $69 or something today which is a bit of a bargain also. By far the easiest things to use for servicing etc.
Have fun :)
Post Posted: Sat Jan 02, 2010 9:10 pm
If you are going to jack the car up, PLEASE use axle stands! It is too easy to drop the car off the jack and end up crushing you. Also, get help with the gearbox. It is not a one man job when you are on your back.
Post Posted: Sat Jan 02, 2010 9:50 pm
x2 Get yourself a trolley Jack(the bigger the better)
Post Posted: Sun Jan 03, 2010 12:45 am
hoist :P
Post Posted: Sun Jan 03, 2010 2:24 am
why not buy some ramps??
thats what i like to use at home. i got to grab some new ones.
I thought you decided to pay someone to do the job properly??
Post Posted: Sun Jan 03, 2010 2:46 am
well, been researching clutches and doesnt seem much to it
cheers for the tips.
i ended up with a trolley and axle stands
just need a transmission jack and i'm off :)
Post Posted: Sun Jan 03, 2010 12:03 pm
+1 the superworks gold stuff is very good. I have a set for my zook tool kit.
If i have to use a 2m piece of pipe on a ratchet, I always use the swg ratchet.
I have had to replace the ratchet once, and it was swapped no questions asked.
To OP. sounds like you got what you needed, good luck.
You dont need a transmission jack, just a tea spoon of concrete.
Post Posted: Sun Jan 03, 2010 2:36 pm
Not sure what that means...
Post Posted: Fri Apr 09, 2010 9:08 pm
harden the F up....
no offence just a little colloquialisation translation around the nation
wow this thread is very old to reply to BUT obsessive vitara lift kit searcher's may stumble across it like i did.
Users browsing this forum: No registered users and 159 guests
