| Sierra reverse switch https://auszookers.com/forum/viewtopic.php?f=5&t=9424 |
| Author: | frogsonvodka [ Tue Jan 26, 2010 12:30 am ] |
| Post subject: | Sierra reverse switch |
Have a manual 95 sierra, need to replace the reverse light switch in gearbox, last resort, however their are two switches into the gearbox, Which one is for the reverse light, the one closet to the engine or furtherest? |
| Author: | want33s [ Tue Jan 26, 2010 1:06 am ] |
| Post subject: | Re: Sierra reverse switch |
NT has 3 switches... WT has 4 switches... If your coily only has 2 then I'll need a pic to tell you which is which. |
| Author: | zuk_244 [ Tue Jan 26, 2010 2:40 am ] |
On my wide track its the one with the bigger pins in the plug. Try unplugging one and see if you reverse lights still work. If ya cant do that because the switch is already stuffed try unpluging the one you think it is and bridge out the 2 pins on the loom side (this should make your reverse lights come on) you may need to have the key on for this. Thats what id do anyway. |
| Author: | Fatzook [ Tue Jan 26, 2010 3:01 am ] |
can you buy these new? Mine is shagged also. |
| Author: | 303zuke [ Tue Jan 26, 2010 5:06 am ] |
want33s wrote: NT has 3 switches...
WT has 4 switches... If your coily only has 2 then I'll need a pic to tell you which is which. If you think about what the gear lever does, it will be easy to work out which is the reverse switch. To select rev, you move the gear knob to the right and back, so inside the gearbox the left side shift rail gets pushed forward. |
| Author: | Fatzook [ Tue Jan 26, 2010 5:12 am ] |
Time for a new stool? |
| Author: | want33s [ Tue Jan 26, 2010 2:09 pm ] |
Fatzook wrote: can you buy these new? Mine is shagged also.
YEP new reverse switches are on Ebay. |
| Author: | MrRocky [ Tue Jan 26, 2010 2:52 pm ] |
er... dumb question but what exactly do the 4th and 5th gear switches do, i recently swaped my 1ltr for 1.6 and 5 spd and just left em hanging. |
| Author: | want33s [ Tue Jan 26, 2010 3:16 pm ] |
MrRocky wrote: er... dumb question but what exactly do the 4th and 5th gear switches do, i recently swaped my 1ltr for 1.6 and 5 spd and just left em hanging.
Part of the pollution control setup on carby 1.3's.. EFI superceeds all of that so you did the right thing by not hooking them up to anything. |
