It is currently Sat Oct 24, 2026 1:22 am
Post Posted: Sat Jan 30, 2010 2:27 pm
Replacing the clutch and need to know which way it goes in. I had the clutch plate and pressure plate sitting together so I wouldn't forget but someone moved them.
Help!
Post Posted: Sat Jan 30, 2010 2:43 pm
The shorter side of the clutch plate usually faces the flywheel.
If that makes sense
thow up some pic of it
Post Posted: Sat Jan 30, 2010 2:54 pm
imagine a flat side and a lumpy side
lumpy side to pressure plate
Post Posted: Sat Jan 30, 2010 2:55 pm
Sweet. I understand what you're saying. That's what I thought it was.
Cheers!
Post Posted: Sat Jan 30, 2010 7:04 pm
It will only go one way. The screws for the pressure plate wont all reach if its backwards.
Post Posted: Sat Jan 30, 2010 7:24 pm
Easiest way to tell is see which way sits nice on the flywheel. If its the wrong way around, the friction surface will stick up from the flywheel due to the clutch plate hitting the flywheel bolts.
Post Posted: Sat Jan 30, 2010 7:30 pm
Also for future reference some clutch plates have it written onto it. Most usually say "flywheel"
Post Posted: Sat Jan 30, 2010 8:00 pm
That's what i thought, but it seemed to fit both ways.
It's in now, and everything bolted up ready to go. Just gotta fill the radiator and kick her in the guts. Thanks for your help guys.
Post Posted: Sat Jan 30, 2010 9:08 pm
thats funny cause that exact same thing happened to just the other week. hope you dont have any dramas mine was all good until the radiator blocked the next day just waiting on new should be here this week.
Users browsing this forum: Google [Bot] and 114 guests
