It is currently Thu Nov 05, 2026 9:00 am
Post Posted: Mon Feb 01, 2010 4:04 pm
Hey guys,
I've done a search but haven't really found any answers.
I have a WT zook and I'm chasing a towbar for it.
A bloke in the same state has a NT towbar that he is willing to sell, he has given me the measurements of 1050mm wide, outer holes roughly 1000mm and inner holes 865mm.
If anyone could please let me know if they have put a NT bar onto a WT before, that would be appreciated.
I do remember reading somewhere that there may be an issue with where the leafs connect to the chassis (I'm a noob and don't know what thats called)
thanks
Adam
Post Posted: Mon Feb 01, 2010 4:17 pm
im almost positive it will fit as the chasis is the same. Just remember to put some spreader plates in otherwise you could stuff the chasis if you go to snatch from the hitch.
Is it a flat tongue or a square reciever type?
Post Posted: Mon Feb 01, 2010 4:40 pm
thanks for your reply..
just a question.. what are spreader plates? i can imagine what they are.. but how do you fab one up?
Here is a pic of the towbar.
Vehicle: jimny
Post Posted: Mon Feb 01, 2010 7:27 pm
ask shep for some tips, he is the towbar fabricator of the month at AZ, especially on towbars
Post Posted: Mon Feb 01, 2010 8:28 pm
wow that is a chunky towbar. Generally speaking WT and NT towbars should be identical (as i own one of each). at the end of the WT chassis is extra RHS welded on the outside, be sure that the towbar mounts to the chassis rail that goes the entire length of the car, not the part that is welded on as this is not available on the NT models.
Id imagine spreader plates would just assist in spreading the load of the towbar on the chassis rail so as not to crimp or bend it if excess force is used, a piece of plate the same width as the chassis rail and a few inches long should do the trick.
Vehicle: 94 Sierra
Post Posted: Mon Feb 28, 2011 6:56 am
Could some let me know if a leafy towbar will fit a coily?
Users browsing this forum: No registered users and 40 guests
