It is currently Fri Oct 16, 2026 10:07 pm
Post Posted: Wed Nov 15, 2017 11:29 am
Im parting out my project, I am open to reasonable offers for all of it or in parts. Not interested in any swaps, cash and pick up only from Corinda QLD
a link to the build thread : viewtopic.php?f=4&t=7102&start=150
[img][IMG]http://i45.photobucket.com/albums/f90/ridge88/IMG_0262.jpg[/img][/img]
[img][IMG]http://i45.photobucket.com/albums/f90/ridge88/IMG_0185.jpg[/img][/img]
Chassis, suspension, body and cage package $2000
Heavily modified LWB chassis. The front end has been extended to suit hilux front springs (OME). Currently dihatsu rocky rear springs are up front ( same measurements just with a offset locating pin) The engine and gearbox mounts have been redone to suit a 4age and t50 gear box. The transfer mounts have been re done and a custom heavy duty t case mount has been made to suit a sierra transfer with a disconnect. Radiator mounts have been remade to fit an alloy 4age radiator.
The rear spring hangers have been modified to suit hilux front springs and the rear shackle mount has been replaced with TG jonny joint mounts. The spring spacing on the rear is NT.
The rear tray section has been built to hold the fuel tank, a sunk in tool box, battery tray and air tank.
The cab has been stripped, modified and repainted. the transmission tunnel has had extensive work to remove rust and suit the t50 box, rear disconnect, cutting breaks etc. Since the whole motor was mounted as low as possible, the transmission tunnel has been built to suit. A section of floor on the passenger side has been raised to fit the exhaust. The cab has a brand new set of rubber body mounts.
A 4 point cage made from 1 3/4” .120 DOM has been started, it is included with the body.
Engine, gearbox, exhaust and radiator $2000 for the package.
ae86 4age 16v with tvis, computer, loom, t50 gear box, extractors and a high mount manifold. The motor has been turned over by hand regularly since I’ve had it. It was rebuilt before i bought it. Full alloy 4age radiator brand new, never used.
Other bits
2 x RCI fixed back bucket seats, new never mounted $230 for the pair
1x 20L fuel tank with fittings $130
1 x rear soft top door $50
1x b pillar $100
A pair of complete doors, $150 for both.
a set of 4, 15x8 alloy rims 6 stud unsure of offset suit hilux diffs etc. Comes with bald 31x10.5 tyres $350
THE FRONT DIFF, TRANSFER CASE AND REAR CENTRE ARE NOT FOR SALE. I can help out with fitting diffs / centre to keep it rolling, but you will need to supply your own parts.
Message for more details
Post Posted: Mon Feb 19, 2018 12:35 pm
Bump package prices dropped.
Lots of drive shafts all with good unis, some wt, nt and bundy make and offer
Cab comes with complete steering column and matching key. Peddle box included .
Vehicle: Sierra g16 efi..and Sierra GTi
Post Posted: Mon Feb 19, 2018 3:08 pm
They should change photobuckets name to ADD$bucket... I got sick of waiting to see the actual pics...Good luck with the part out!
Post Posted: Sat Mar 17, 2018 11:18 am
BUMP, front diff, transfer case and rear centre not for sale. Everything else is up for sale, I will do a deal on the lot.
Post Posted: Sat Jun 09, 2018 10:18 am
Prices dropped
A link to the ad on gum tree, the photos work there.
https://www.gumtree.com.au/s-view-detai ... 1186330707
Users browsing this forum: No registered users and 62 guests
