| Author |
Message |
lauby
Joined: Sat Dec 05, 2009 10:30 pm Posts: 254 Location: Gold Coast
Vehicle: 91 Sierra
 Posted: Thu Jul 22, 2010 6:37 am |
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Thu Jul 22, 2010 6:45 am |
The diff plug is just a 3/8" drive... Stick your ratchet or something on there with a good length breaker bar...
_________________ I want my old sig back
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Thu Jul 22, 2010 7:07 am |
There are sump plug removal sockets that have a much squarer profile than a ratchet drive will have, however with care a ratchet will do it.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu Jul 22, 2010 7:16 am |
*Tie rod remover = Hammer.
*Socket = 50mm not 51mm. Will only be available in 3/4 drive.. I bought a socket and 3/4 breakerbar from Ripco for $60.
*3/8 drive ratchet will work fine.
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Thu Jul 22, 2010 7:37 am |
lauby wrote: 3. The name of the ' thing with a square head ' to remove the diff drain plug so i can buy one of these as well.
I have a metric plug key tool from Autobarn. They look like a spanner with a bunch of different size shafts on the end. They are crap and a 3/8 socket drive is easier.
I use a 1/2" breaker bar with a 1/2" to 3/8" adaptor on the end. That way my ratchet isn't damaged on those really tight plugs...
There is a special socket you can buy to do the job. Not sure where you can buy them though.
royce
 Posted: Thu Jul 22, 2010 7:58 am |
the 3/8 ratchet idea is shit if the drive has rounded edges
lowrange sells the socket made for the job
squizzytaylor
Joined: Sat Sep 26, 2009 11:30 pm Posts: 381 Location: Bogged near Morisset
 Posted: Thu Jul 22, 2010 7:59 am |
lauby wrote: 3. The name of the ' thing with a square head ' to remove the diff drain plug so i can buy one of these as well. .
They are actually 10mm, I got mine through Repco (about $25) and they had to order it in, stuffed if I can remember the brand though, look like this
http://www.lasertools.co.uk/item.aspx?cat=512&item=1698
lauby
Vehicle: 91 Sierra
 Posted: Thu Jul 22, 2010 10:59 am |
found a web site
1. KINCROME SOCKET 3/4DR 50MM - $27.95 incl GST
KINCROME ADAPTOR 3/4 TO 1/2 - $18.95 incl GST
2. KINCROME TIE ROD END/A-PULLER - $30.95 incl GST
3. Drain Plug Wrench 8mm/10mm Sq. - still looking. Couldn't find it on LR Royce, will try an el cheapo 3/8 drive ratchet in the mean time / try repco.
cheers
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Thu Jul 22, 2010 11:10 am |
want33s wrote: *Tie rod remover = Hammer.
Considering you will only be using it once or twice use a couple hammers preferably 3lb ones if you have them. Place one against one side of the tie rod end and hit the opposite side of the rod end with the other hammer. After a couple of decent hits it should vibrate itself loose.
lauby
Vehicle: 91 Sierra
 Posted: Thu Jul 22, 2010 11:13 am |
 i knew there'd be a strong following for the hammer option round here
