It is currently Sat Jul 18, 2026 10:40 pm
Post Posted: Wed Nov 16, 2011 10:22 am
As it states I am after front and rear diff centers, also a set of rear axles.
In need of a set of driveshafts as well.
Thanks
Vehicle: Jimmny 2005
Post Posted: Wed Nov 16, 2011 11:55 am
I have a full set of drive shafts from a 2005 Jimny
a front rear diff centre 4.3:1 ratio in good condition with slight shaft seal leak.
Also have a full front steering and diff /hub assy. Its complete, suspension and steering and suspension. Don't want to bust it up at this stage.
Its located in Brisbane.
PM me if you are interested.
Post Posted: Wed Nov 16, 2011 4:56 pm
For what kind of car?
Post Posted: Wed Nov 16, 2011 10:00 pm
Suzuki Jimny JLX VVT, build date 2005 .
Also have available a complete power steering kit, pump , brackets, reservoir, tubes, steering box.
For the Front Axle assy I have vacuum valves, tubes etc.
Wiring harness, 4Wd controller, and electric select transfer case.
( this could be modified to go with a manual transfer case by using a switch to switch in the front Hubs).
you can build up to what ever you want.
Hope this helps.
Post Posted: Thu Nov 17, 2011 3:11 am
Sorry the centers and driveshafts I want are for a Sierra WT.
Thanks
Users browsing this forum: No registered users and 2 guests
