It is currently Sat Jul 18, 2026 7:22 pm
Vehicle: 93 Sierra 2'' lift 30'' tires
Post Posted: Fri Nov 18, 2011 11:02 pm
I bent my front diff, and now the axle shafts are stuck in there too. There's really nothing I can do so I was wondering if anyone has one they don't need.
Cheers, josh
Post Posted: Fri Nov 18, 2011 11:03 pm
i have a beefed up housing forsale. freight might be a killer lol
Post Posted: Fri Nov 18, 2011 11:39 pm
If the housing is so bent the axles are stuck then it is rooted and won't be a loss if you use an angle grinder to cut the housing to bits. I'd cut the housing either side of the pumpkin, axles will come out then.
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Sat Nov 19, 2011 12:17 am
Ive got a complete WT front diff minus the left hand side shaft...
If at first you don't succeed, get a bigger hammer
Post Posted: Sat Nov 19, 2011 10:22 pm
Hey mate. Is that the longer shaft or the shorter one? And is it for a leafy? Cheers
Post Posted: Sat Nov 19, 2011 10:23 pm
Ahh okay I think that's probably what I'll have to do, cheers for that
Post Posted: Sat Nov 19, 2011 10:52 pm
It came out of my SJ70 W/T which is a leafy, and the left side drive shaft is rooted :/ the teeth have been shredded, and you will need new hubs
Post Posted: Sat Nov 19, 2011 10:58 pm
Alright well I've got hubs and everything, I'm just struggling to picture it, is the left side drive shaft the shorted side or the longer side if that makes sense? I don't really know the terms for things haha. And so apart from that axle shaft missing, it is just a bolt on Job? I don't need to do anything to the diff gears and stuff? Cheers, as I said before, I'm new to this stuff :p
Post Posted: Sat Nov 19, 2011 11:01 pm
Yeah mate, it is a complete diff aside from the left hand shaft, which IS the longer one. You might want to get a diff O\haul kit aswel, but its there for you cheap
Post Posted: Mon Nov 21, 2011 1:31 am
Thanks mate, shame that the left side is buggered because that's the side of mine that's buggered too :/ I'll have to get back to you on that one. Would anyone happen to have a left side axle shaft and cv haha :p
Users browsing this forum: No registered users and 9 guests
