It is currently Sat Jul 18, 2026 11:23 am
Post Posted: Thu Jan 05, 2012 8:01 am
Gidday fellas,
I am needing an old brake disc or brake drum with a 5 x 5.5 stud pattern to make a special tool to help pull the hubs out of an old jeep. :oops:
Anyone have some dead bits they want to throw out?
northen suburbs of perth preferably- but I dont mind trekking South if I have to :lol:
Thanks,
stephen.
Post Posted: Thu Jan 05, 2012 8:27 am
have a zuk rear wheel holder ? yours if it suits
Post Posted: Thu Jan 05, 2012 8:51 am
I have a couple of old sierra disks you can have , but im in Lesmurdie :)
lost in suzuki space
Post Posted: Thu Jan 05, 2012 8:57 am
The old jeep hubs are pretty well stuck to the axles
(tapered axle shaft with keyway that the hub is tightened on with 567595ft/lbs tension.
I was going to belt the bejeezus out of the drums to loosen the hub while winding up the wheel puller.
But.....
I have been advised to be gentle to the relatively fragile and ancient jeep drums and pull directly on the wheelnuts- so I figured if I bolt on an old knackered suzuki disk or drum to the hub, using the wheelnuts- it gives me something to hook the wheel puller onto without wrecking the original drums.
An old disc is probably the easiest option, but a drum would work too.
Stephen.
Users browsing this forum: No registered users and 25 guests
