It is currently Mon Jul 13, 2026 4:52 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2  Next
Post Posted: Wed Nov 03, 2010 11:38 am
Problem solves
Post Posted: Wed Nov 03, 2010 11:54 am
high or low ratio? how high do you want 3.7's?
Post Posted: Wed Nov 03, 2010 12:35 pm
i dont think anyone makes 4inch springs. They would have a hell of an arc in them and be shit.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Wed Nov 03, 2010 12:36 pm
reduction gears can get from lowrange.com or locktup4x4. exchange rate is awesome atm so i would suggest lowrange.
79' LJ80 (sold) :(
Post Posted: Wed Nov 03, 2010 7:10 pm
Sorry guys I was half asleep wen I put this up, any ratios in the 4:1 or 5:1 so low ratio to clarify my cock up cheers boys
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Wed Nov 03, 2010 7:15 pm
I have a pair of Superior Engineering drop shackles here.
They were $599 a pair new.
I'll take $350 for them.
Post Posted: Wed Nov 03, 2010 10:42 pm
Uh 2" Zooks RUF and 2" Lux Fronts in Rear is roughly 4" of lift
I'd probably suggest that?
Post Posted: Wed Nov 03, 2010 10:59 pm
Cheers mate I'll look into that 1
Post Posted: Wed Nov 03, 2010 11:56 pm
Lux fronts are 60mm wide arent they? They would be stiff as shit too???
Kermy, mate, what your after is length, not height... may I suggest mazda 323 wagon rears (not sure on year)
they are 50mm wide and are longggg :D
Post Posted: Thu Nov 04, 2010 12:00 am
Cj jeep springs !!!
Post Posted: Thu Nov 04, 2010 12:04 am
If he wants lift, you aren't gonna find 2" lifted Mazda Wagon springs..
Hilux fronts are prettymuch the easiest option
Yes they are 60mm wide, and it's not that much messing around to make them fit.
Stiff? Not really.. I ordered the petrol engined light duty 2" lifted.. Theyll be fairly soft especially when i take a spring out
tanshi wrote:
Cj jeep springs !!!
YJ is the best conversion isnt it?
Theyre 60mm also though
Post Posted: Thu Nov 04, 2010 12:38 am
Never said you would find 2" lifted mazda wagon rears mate... read post before you reply mate, I was saying that length is better then lift...
Post Posted: Thu Nov 04, 2010 12:39 am
who says YJ is better than CJ??
Cj fronts are 50mm leaves, sounds like a better option to me.
Post Posted: Thu Nov 04, 2010 6:06 am
drop shackles here...
http://auszookers.com/index.php?name=Fo ... ic&t=15717
Post Posted: Thu Nov 04, 2010 11:43 am
Read the post before you reply mate, he wanted 4" springs.. So he ain't gonna settle for Mazda Wagon ones.
2" Lux Fronts are roughly equivilent to a 4" lift in the rear.. Whereas the Mazda would be lucky to match a 2" lifted spring
Just sayin' is all.
Doesn't matter what's better or what you think.. If he wants lift, then he can have it.. And i'm offering relevent advice
Post Posted: Thu Nov 04, 2010 2:02 pm
Just sayin' is all.
Well I fitted brand new 2" lifted YN65 lux fronts to the rear of my ute, and needed 3" extended shackles to get them anywhere near the height of my sagged RUF on standard shackles at the front end.
So they probably sit lower than 2" lifted zook springs.
And they are 60mm wide, and require moving the spring or shackle hangers, and they are super stiff with only 3 leaves remaining.
My advice would be to go 2" spring and if you need more height look into a Body Lift :roll:
Post Posted: Thu Nov 04, 2010 7:27 pm
Just sayin' is all.
if its lift he is after then running a body lift and longer springs would be more practical... :?
Body lifts dont sag... springs do... and at least if he is running the long flatter springs he will have flex and articulation... A 4" spring in a suzuki would be a fucking joke... waste of time...
Post Posted: Thu Nov 04, 2010 9:32 pm
I've got 4"" cab lift already I might just look intogettinmy 2" springs reset to 4" and just put extended shavkes on
Post Posted: Thu Nov 04, 2010 9:53 pm
What do you need all this lift for? what size tires are you trying to clear?
95 Sierra, SPOA, 33 JT2s, 5.12s.
Post Posted: Thu Nov 04, 2010 10:00 pm
4" cab lift 8O
Why not throw in some SPOA for good measure?? What could you possibly need that much lift for?
Post Posted: Thu Nov 04, 2010 10:28 pm
Ive got 33" ATM I want 35"s I can fit them now they just scrub out hardcore,
Post Posted: Thu Nov 04, 2010 10:30 pm
Also I put the 4" cab lift on for clearane for top mount intercooler for my 4age 20v when I blow it
2 inches more spring lift wont stop them scrubbing, i would suggest a virtual lift is the only way 35s are gonna fit
Post Posted: Thu Nov 04, 2010 10:36 pm
What do to mean by virtual???
Post Posted: Thu Nov 04, 2010 10:40 pm
guard chopping, 35s is gonna require alot.
Post Posted: Thu Nov 04, 2010 10:48 pm
As you can see by the image Iv got 6" bushwacker flares and ihave chopped out the guards and they fit, I just need more articulation and less scrbbihge, 33"s full lol topped out and bottomed out don't touch a thing so 2" extra in the springs with 35" shouldn't be a problem
Post Posted: Thu Nov 04, 2010 10:49 pm
I hope!!
Post Posted: Thu Nov 04, 2010 10:54 pm
extra 2 inch of lift isnt going to help with articulation though.
Post Posted: Fri Nov 05, 2010 3:08 am
True. And getting 2" springs and having them reset to 4" is not going to work. You would need a massively longer top leaf.
I just can't understand why you need 4" cab lift + 4" suspension lift + 1" shackle lift to clear tiny 35's, AFTER you have cut the guards :? :? :?
You're doing it wrong. :roll:
