It is currently Fri Jul 03, 2026 7:13 am
Post Posted: Tue Feb 28, 2012 5:55 pm
preferably near ipswich region
looking to pay around the $250 mark
Post Posted: Tue Feb 28, 2012 6:02 pm
For the coily??
Post Posted: Tue Feb 28, 2012 7:19 pm
Yep for the coily. Time to piss off those struts.
TWIN LOCK IT & JUST DRIVE!
Post Posted: Tue Feb 28, 2012 7:25 pm
Have fun...Be patient, it's a very painful process.
Post Posted: Tue Feb 28, 2012 8:02 pm
Easy. It will be built slowly and once.
Post Posted: Tue Feb 28, 2012 8:09 pm
Have a look under the front of mine and see if you still have the easy opinion :rofl:
Post Posted: Tue Feb 28, 2012 8:24 pm
This question would normally be better suited to tech, but what are your plans as far as links go?
Are you hoping to re-use the radius arms?
If yes, you will need to run the coily HP centre, and knuckles, and tie rod.
If this is the case, all you really need is a WT housing and CV's......
Post Posted: Tue Feb 28, 2012 8:27 pm
Carnt see whats so difficult about it.
Post Posted: Tue Feb 28, 2012 8:34 pm
it wouldn't be suited for tech because i'm wanting to buy, hence why it's in the 'i want it' thread.
i have no idea, i just want a diff!
once i have the diff, i will then ask for advice in the appropriate section!
Post Posted: Tue Feb 28, 2012 8:36 pm
I should have got you to do mine then :rofl: Packaging it all to fit is the main problem, steering is a big issue. Oh yeh, there is a WT housing at Mr.Fats house that probably isn't getting used. Will have to double check though :wink:
Post Posted: Tue Feb 28, 2012 8:38 pm
You've misinterpreted my post. :?
I said that MY question was probably better suited to tech, seeing as this is a wanted ad and all. :roll:
And my question is quite relevant to your plight, as you probably don't NEED a full diff (@$250) when you could get away with a bare housing and CV's (@$100) if you plan to re-use your diff centre, steering and knuckle/ hub assembly.
Coily drivers :roll:
:thefinger:
Post Posted: Tue Feb 28, 2012 8:42 pm
i want a full diff so i can run chromo cv's and an arb locker
Post Posted: Tue Feb 28, 2012 8:45 pm
So you'll need a NT rear diff centre (3.9 with 26 spline side gears), and a WT housing and knuckles. ( unless you plan to run the 22 spline stuff at first)
Want 33's may have those parts.
Post Posted: Fri Mar 02, 2012 8:15 pm
bump, want this!
Post Posted: Sat Mar 03, 2012 11:15 am
I have one bit it is on the mid north coast nsw
Post Posted: Sat Mar 03, 2012 12:11 pm
As previously mentioned...I have a wt housing at Fatzook's house. You won't need axels or cv's since you want cromo's. I suggest you send 2stroker a PM for the swivel hubs and bearing hubs. You will still need a NT rear centre so you can match your coily rear ratio :wink:
Post Posted: Sat Mar 03, 2012 4:29 pm
i have one kicking round but its west syd,
BUMP!!!
Post Posted: Sat Mar 03, 2012 7:59 pm
okay i want a COMPLETE wide track diff, hub to hub, that's all.
i'm not gonna fuck around with nt centres an all that crap yet cause i don't have the money for chromos
Post Posted: Sat Mar 03, 2012 8:09 pm
So your going to run a 3.7 ratio in the front and a 3.9 ratio in the rear? That should work well :roll: We are only offering suggestions. My coily has just gone through this process, it's far from an easy undertaking. I'm sure you will figure all that out though :wink:
Post Posted: Sat Mar 03, 2012 8:22 pm
It's going to be a slow build, she wants a wide track front diff, why is that so hard to grasp? Want a complete wide track diff, yea it will eventually be under her coily with chromos, Arb locker and matching centres
Post Posted: Sun Mar 04, 2012 3:38 pm
Bek I have one for you, I have sent a PM with my number please call me anytime and we will sort out a deal.
Kas
Post Posted: Tue Mar 06, 2012 11:39 am
Why is it so hard to grasp that people who have just completed the same conversion are offering up their experiances as to what really is and isnt needed to do this conversion?
You cant use the center at all so why buy it
depending on how you set the suspension up, either using the orignal links or making all new ones you cant use the WT steering so why buy it
Perhaps instead of listening to a few people that reckon it will be easy and jsut go grab a diff, you should start a tech thread asking about what some of the common pitfalls to this conversion are, or indeep if you are jsut wanting to get rid of the struts, what options are availble to do this, you can do it while keeping the coily diff
Post Posted: Tue Mar 06, 2012 12:42 pm
I guess some people just need to make their own mistakes. :roll:
Post Posted: Tue Mar 06, 2012 3:20 pm
OK, so.... you're trying to convince a woman of your point of view using an argument based on logic and fact.
Did you really think that was going to work? :mrgreen:
Post Posted: Tue Mar 06, 2012 4:41 pm
I have a WT housing, swivels, 3.9 crown wheel and pinion. which you could have had for less than a whole diff, but eh...
the guys were just trying to save you money you could have spent on the chromos.
Post Posted: Wed Mar 07, 2012 8:41 am
You arent the first person to ever tell me this, if they ever make a women that deals in logic and common sense ill be all over that like a fat kid in a donut shop pompoms
Post Posted: Wed Mar 07, 2012 11:45 pm
Then dont be holding your breathe! :rofl:
Post Posted: Sun Jun 03, 2012 8:22 pm
bump bump bump, in DESPERATE need of one of these now!!
Post Posted: Sun Jun 03, 2012 8:36 pm
i have one in west syd
Post Posted: Mon Jun 04, 2012 6:03 am
i'm in qld.. in ipswich..
Users browsing this forum: Google [Bot] and 35 guests
