It is currently Sun Jul 12, 2026 7:42 am
Post Posted: Thu May 06, 2010 9:35 am
Hi All,
I am after an air tank for on board air. Also, if you have any bits and pieces around that would help setting up the onboard air would also be appriciated. Prefer bits in brissy.
Rusho
Post Posted: Thu May 06, 2010 9:50 am
see if ya can find an old fire extinguisher....they can be had for free....or next to nothing... ive picked up 2 along the way! they are long and thin and prefect for fitting in a zook somewhere...and strong as!
Go Hard, Trailer Home
Post Posted: Thu May 06, 2010 9:58 am
i got an alluminium 9L tank with multiple ports for 100 bucks off hobzee i think it was.. expensive maybe but its a wicked pro made tank and i know it wont fail because of my bad workmanship :D
Post Posted: Thu May 06, 2010 9:59 am
I like your style :wink:
Post Posted: Thu May 06, 2010 10:20 am
I have bought two of these.. One for my Zook, the other for the Trol.
http://cgi.ebay.com.au/Air-compressor-A ... 45f08661af
As for air tanks..... Extinguishers are certainly strong enough but are only steel and will rust quickly ..... They also only have one hole so draining them isn't easy...
Something like this is a bit dearer but is made for the job and will last a long time.
http://cgi.ebay.com.au/Air-Tank-10-litr ... 45ef4d86b4
Post Posted: Thu May 06, 2010 10:24 am
Cheers Jas, the manifold would definately sort everything out and make it a much easier install
Post Posted: Thu May 06, 2010 10:48 am
I have 2 stainless fire extinguishers at my mates place. No rust :D They come from fire supression systems in McDonalds kitchens. They need to be stainless for health reasons.
Rusho, I'll see if I can find them. They are at Charlies place.
Post Posted: Thu May 06, 2010 11:09 am
Excellent smithers 8)
Post Posted: Thu May 06, 2010 11:34 am
I use a scuba tank, get lots of air fills from that ;)
I want my old sig back :(
Post Posted: Thu May 06, 2010 1:22 pm
one of the ones i have is alloy, its got date stamps on it dating back 30 years...no rust :wink:
how big do ya wanna go?
http://cgi.ebay.com.au/FIRE-EXTINGUISHE ... 53e11b1b1c
nice stainless one...in sydney but
http://cgi.ebay.com.au/4-5kg-POWDER-FIR ... 3cacc13aee
Post Posted: Thu May 06, 2010 8:30 pm
Ok so the extinguisher/rust issue is solved but how do you drain the water out of the tank????
Post Posted: Thu May 06, 2010 8:53 pm
If I get one cheap enough I will get a drain plug cut and welded into it. Should be ok??
Vehicle: 75 Cruiser
Post Posted: Thu May 06, 2010 9:51 pm
when the car is on it's side? :)
Post Posted: Thu May 06, 2010 10:28 pm
:P Go to a truck wreckers they will be everywhere and will already have the fitting :)
growing old is nature, growing up is choice.
Post Posted: Fri May 07, 2010 12:04 pm
depends on how often you use it and how much water collects in there.... down here in sa we dont have the humidity you guys get up there, so i didnt bother with a drain, even on my work compressor which gets used 40+ hours a week...flat out might be lucky if it gets drained once every 6 months :oops:
Post Posted: Fri May 07, 2010 3:01 pm
Have TIG. Will use :D
Post Posted: Sat May 08, 2010 2:37 am
man if your out samford way sometime jsut go to the dump they have a big thing for them aslong as the supervior guy aint there you can take as many as you like
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Sun Jul 18, 2010 5:06 am
what size tank/fire extinguisher would you need to get. i have one that is just as tall as a 600ml bottle but a bit wider, is that to small and what could you run off one of these setups? i am running it off a vitara compressor if that is any help.
thanks greg
Post Posted: Sun Jul 18, 2010 7:20 pm
I have an small alloy fire extinguisher as an air tank in my Rodeo. Just drilled/tapped a few extra 1/4" BSPT ports in it, one on the bottom for a drain. Wall thickness was easily thick enough to do this.
Post Posted: Thu Jul 22, 2010 10:03 am
want33s wrote:
I see you have a perfectly functional filing system there! :P
255 characters
Post Posted: Thu Jul 22, 2010 11:03 pm
hutch wrote:
Works for me!!!! :D
Users browsing this forum: No registered users and 70 guests
