| Alternator upgrade parts https://auszookers.com/forum/viewtopic.php?f=8&t=14089 |
| Author: | 819FKA [ Thu Aug 05, 2010 2:12 am ] |
| Post subject: | Alternator upgrade parts |
Hi peeps just seeing of any1 can help beofre i buy all the stuff myself i need 110Amp alternator Swift/Barina Water Pump Swift/Barina Water pump and Crank pulleys Any help would be greatly appreciated |
| Author: | Built4thrashing [ Thu Aug 05, 2010 8:34 am ] |
| Post subject: | Re: Alternator upgrade parts |
just get new waterpump. $60 from most decent parts places and if ya lucky a new alt can be found for as little as $190. and you will need a 3PK840 belt or 2. B4T |
| Author: | Jord [ Sun Aug 15, 2010 2:02 am ] |
are these the parts for a sierra upgrade? |
| Author: | 819FKA [ Mon Aug 23, 2010 10:11 pm ] |
yes |
| Author: | hutch [ Tue Aug 24, 2010 6:45 am ] |
819FKA wrote: Hi peeps just seeing of any1 can help beofre i buy all the stuff myself
i need 110Amp alternator Swift/Barina Water Pump Swift/Barina Water pump and Crank pulleys Any help would be greatly appreciated I have a ford alternator (misubishi brand) ready to bolt straight in. I did 2 when I did mine... no need to change anything else. Just drill out the bottom mount bracket to 10mm. My build up on NBS has pics... about 3/4 down the page. http://nbs4x4club.com/forum/index.php?topic=11573.60 PM if you are interested. |
| Author: | needmorelift [ Tue Aug 24, 2010 8:54 am ] |
if you dont want to change your water pump then you can just use a vitara water pump pulley just make sure its the one with 4 bolt holes..crank pulley i got a big double one off a '89 model swift, again you need the one with 4 bolt holes not 5 like most are good luck |
