| URGENT wt diff centre https://auszookers.com/forum/viewtopic.php?f=8&t=14725 |
| Author: | mcwilly [ Wed Sep 01, 2010 6:55 am ] |
| Post subject: | URGENT wt diff centre |
Need a rear wt diff centre asap |
| Author: | scotteastham [ Wed Sep 01, 2010 6:57 am ] |
| Post subject: | Re: URGENT wt diff centre |
i have a rear center got it with my seirra how do u tell what type it is also have sum front and rear diffs with spring over conversion with high steer |
| Author: | mcwilly [ Wed Sep 01, 2010 7:20 am ] |
not sure how u tell the difference. i have all the housings etc just need the centre unless ur gettin rid of it all cheap |
| Author: | lump_a_charcoal [ Wed Sep 01, 2010 8:14 am ] |
What ratio are you after? I have a few bits here... |
| Author: | SuziBlu [ Wed Sep 01, 2010 8:19 am ] |
wt = 3.7-1 |
| Author: | Brett [ Wed Sep 01, 2010 8:48 am ] |
i have a rear but needs a new pinoin bearing. pm me if you want it |
| Author: | scotteastham [ Wed Sep 01, 2010 8:48 am ] |
mcwilly wrote: not sure how u tell the difference. i have all the housings etc just need the centre unless ur gettin rid of it all cheap i got one center witch is out prity sure its a lsd
| Author: | mcwilly [ Wed Sep 01, 2010 8:57 am ] |
after a 3.7 |
| Author: | 31zook [ Wed Sep 01, 2010 9:42 am ] |
haha, ill check tomorrow chris. i have a complete rear center you can pick up for $80, it has a whine, but will do till you sort yourself out, i also have a ring and pin set for the one it sounds like you have blown.. |
