| Bunderra rear diff https://auszookers.com/forum/viewtopic.php?f=8&t=16406 |
| Author: | turbo_deo [ Tue Nov 02, 2010 5:21 am ] |
| Post subject: | Bunderra rear diff |
Hi guys, I'm chasing a bunderra rear diff assembly in the Newcastle area, not had to much luck with the local wreckers, and do hilux centers fit bundy diffs? Thanks josh |
| Author: | want33s [ Tue Nov 02, 2010 5:37 am ] |
| Post subject: | Re: Bunderra rear diff |
Yes hilux centres fit Bundera housings. Remydog has a pair for sale. |
| Author: | Joe [ Tue Nov 02, 2010 5:40 am ] |
http://auszookers.com/index.php?name=Fo ... ic&t=16277 |
| Author: | turbo_deo [ Tue Nov 02, 2010 6:13 am ] |
Thanks guys I will chase it up |
| Author: | ck13488 [ Tue Nov 02, 2010 8:56 am ] |
have you tried beresfield spares on weakleys drive or Budgewoi Auto Wreckers at kurri kurri? |
| Author: | remydog05 [ Tue Nov 02, 2010 8:24 pm ] |
Cheers Joe |
| Author: | turbo_deo [ Tue Nov 02, 2010 9:01 pm ] |
Tried Bero wrecker but halfa on hold tells me they don't, will try kurri |
| Author: | turbo_deo [ Tue Nov 02, 2010 11:00 pm ] |
Is there any difference between a leaf sprung and coil sprung bundy diff, I have found a leaf one local but noticed most used are coil sprung |
| Author: | turbo_deo [ Tue Nov 02, 2010 11:02 pm ] |
| Author: | atari4x4 [ Tue Nov 02, 2010 11:19 pm ] |
there was no leaf sprung Bundera made... the reason you want the bundy rear diff is because the diff pumpkin is off set to the right like the sierra. |
| Author: | turbo_deo [ Tue Nov 02, 2010 11:34 pm ] |
yea thats what i thought the wreckers telling me there was both made |
| Author: | Jccck [ Tue Nov 02, 2010 11:55 pm ] |
Give Hunter 4wd Spares a try, at Lemontree Passage They've always seemed pretty knowledgable to me.. |
| Author: | scotteastham [ Wed Nov 03, 2010 12:08 am ] |
hey bud i got a 1988 sierra with budarah rear hilux front spoa 1.6 vitara motor carby swb soft top heaps of spares gards bonnet clip rollover hoop top part 3000 its your goes well not cert but is ready to 0432839738 3 monts reg |
| Author: | turbo_deo [ Wed Nov 03, 2010 12:47 am ] |
scotteastham wrote: hey bud i got a 1988 sierra with budarah rear hilux front spoa 1.6 vitara motor carby swb soft top heaps of spares gards bonnet clip rollover hoop top part 3000 its your goes well not cert but is ready to 0432839738 3 monts reg
Hey mate I don't have the time or room to part out a car but if your keen to part with rearend and shaft send us a pm |
| Author: | superduki [ Thu Nov 04, 2010 8:47 am ] |
turbo_deo wrote: yea thats what i thought the wreckers telling me there was both made
Sort of.... Bundera had non floating rear axles (same setup as a zook), hilux centre will fit. The "mid wheel base cruiser" has a floating rear axle setup, offset exactly like a bundera, heavier 75 series centre and axles. But from the outside, mwb cruiser and the bundera look the same apart from the spring setup, so thats why your wrecker is confusing you! Look for a bundera one mate if you weanna fit a lux centre. Cheers, Superduki. |
