https://auszookers.com/forum/
1'' extended shackles
https://auszookers.com/forum/viewtopic.php?f=8&t=19651
Author:  stiky [ Wed Mar 02, 2011 10:38 pm ]
Post subject:  1'' extended shackles
Any 1 know of shackles 1'' extended as i am in qld and 2'' stand out like dogs balls :crazy:
Author:  Fatzook [ Wed Mar 02, 2011 10:39 pm ]
Post subject:  Re: 1'' extended shackles
What are you trying to achieve? Better shackle angle? Lift? etc...
Author:  stiky [ Wed Mar 02, 2011 10:44 pm ]
Both i guess i have 2'' springs an wanted to do a shackle lift looking for better performance outa my suspension setup 1 of my front shackles has a bit of damage so i am searching my options not so much looking for lift seen a sierra the other day with 2'' extended shackles an they were so obvious looked outa place
Author:  Fatzook [ Wed Mar 02, 2011 10:46 pm ]
I know you want extended shackles, but do you NEED them? They are good for correcting sackle angles when doing RUF, but imO should not be used for lift only. Do you have a side on pic of your shackle angle?
Author:  stiky [ Wed Mar 02, 2011 10:48 pm ]
no i dont i can take one do shackles improve suspension travel?
Author:  Fatzook [ Wed Mar 02, 2011 10:53 pm ]
yes and no. Its more that they can improve the 'range' of travel. If your shackles are sitting almost horizontal, any uptravel may cause the shackles to invert. Extended shackles would thenlessen the angle, giving a more usefull uptravel. Down travel will also be increased, but only by half of the extended value of the shackle.
They are no miracle cure for poor flex. But they are effective given the right circumstances.
Pic would be good :wink:
Author:  stiky [ Wed Mar 02, 2011 11:12 pm ]
they almost strait up and down slight angle faward couldnt upload pic pic was to large an still getting used to my new macbook so not sure how to downsize yet
Author:  Choppy [ Thu Mar 03, 2011 1:19 am ]
For increased suspension abilites i.e. more softness/travel you ideally want your shackle angle to be close to 45 as it allows more ideal upwards travel and droop.
By increasing shackle length you effectively reduce this angle (and it sounds like yours is failry limted already) in order to gain more anlge longer leafs are required as the eye of the leaf pushes the bottom of the shackle out wards from the chassis.
As fat said they can work under the right circumstances but in others actually increase the harshness of ride
However back the 1 inch shackles i was also wondering about them inorder to regain some height in the back of my car. I have king springs in the front of my car which havent sagged at all, however my rear OME's have sagged substantially (have a good shckle angle) and the whole car know sits drooped towards the rear. or i could just get OME fronts which will soften the front aswell
Author:  stiky [ Thu Mar 03, 2011 3:07 am ]
ok what length is the standaard leaf pack if i did have 2'' springs should my shackle angle be 45 deg?
Author:  Fatzook [ Thu Mar 03, 2011 3:09 am ]
You need longer springs. If your stockos are near verticle, then ANY extended shackles will make them even closer to vericle. This will reduce the springs ability to compress under load ( less uptravel) and make the ride very harsh.
And Choppy; How much have yor springs sagged? 1" extended shackles would give a barely noticable 10mm of lift. :?
Author:  Fatzook [ Thu Mar 03, 2011 3:11 am ]
A new longer spring will have it sitting at 30 degrees. A sagged longer spring will sit at 45ish. But this all depends on the spring manufacturer as they are all dfferent lengths. If you do not already have RUF, then it might be worth looking into. :wink:
Author:  stiky [ Thu Mar 03, 2011 5:14 am ]
i got kings i was under the impression they where 2'' extended my shackels would be prob 25 deg or so i my ride is stiff i am going to remove a leaf should soften it up a bit i will have another go at uploading the pic i
Author:  Choppy [ Thu Mar 03, 2011 5:29 am ]
this is what i was thinking in oreder to lift it back to 'level' id have to use 2 inch shackles but i dont really want to have significantly different sized shackles fornt and rear. ill probably just replace my king fronts with OME and let it sag to an even level
Author:  Choppy [ Thu Mar 03, 2011 5:32 am ]
almost exact situation i had, i used to have kings all round and foudnt hem terrible for ride comfort. YES as some will say they dont sag easily and give you more then 2" lift but the harshness of ride is too much to handle IMO. I removed leaves and was riding on 3 front and back, helped a little but once i put OME in the rear the difference was astounding considering their 5 leaves ...
As you stated at the start of the thread your looking for suspension improvement, removing leaves or getting softer springs will do this. I think in your case this is the best option and perhaps just get another set of std. shackles rather then extended to start off with. There are alot of sierras around with just 2" spring lifts on 29' or 30' tyers which can go anywhere. If you then wont more height look into BL and extended shackles but you be amazed how much more capable your rig will be wwith softer springs
LOW and FLEXY is the way
Author:  stiky [ Thu Mar 03, 2011 8:03 am ]
Ok you convinced me i am getting rid of some leaves outa my sprigs if it still rides like a rock i may have to look into ome springs
Author:  stiky [ Thu Mar 03, 2011 8:04 am ]
thanks choppy
Author:  Choppy [ Thu Mar 03, 2011 9:22 am ]
no worries mate, i only know as i had the exact same symptoms. ive also heard some good things about EFS springs as their fronts are slighlty longer then most other brands, everyone will have their own opionins though
