| datsun 120y radiaotor 1ltr https://auszookers.com/forum/viewtopic.php?f=8&t=20472 |
| Author: | Verm1n [ Tue Mar 29, 2011 1:12 pm ] |
| Post subject: | datsun 120y radiaotor 1ltr |
as title says.. inlets/outlets are on the passenger side.. the 1ltr sierra ones have it on the drivers side.. Brad ipswich area |
| Author: | Fity [ Tue Mar 29, 2011 10:00 pm ] |
| Post subject: | Re: datsun 120y radiaotor 1ltr |
I got one from a LJ50 120y conversion if that fits. |
| Author: | Verm1n [ Tue Mar 29, 2011 10:09 pm ] |
how much u chasing for it?? post to bris?? Brad |
| Author: | Fity [ Tue Mar 29, 2011 10:19 pm ] |
It's been a while since I looked at it and I can't remember if it was great or crap. I will dig it out and let you know. |
| Author: | Verm1n [ Tue Mar 29, 2011 11:50 pm ] |
cheers mate, i doubt it could be worse than mine :S |
| Author: | tanshi [ Tue Mar 29, 2011 11:59 pm ] |
I just had a sierra rad modded, to have both inlets on the other side. I have it triple cored too and it was $300. if your just swapping inlets it wouldnt cost much. |
| Author: | Verm1n [ Wed Mar 30, 2011 12:50 am ] |
true.. i got a dato 1 but the core is f@#$'d might even look at a bigger radiator yet.. cheers though.. p.m the place where u got it done tanshi |
| Author: | tanshi [ Wed Mar 30, 2011 12:56 am ] |
a 2 litre vit one has the inlets on the right side. you might have a hard time fitting it, baleno also its a place down near the cemitary, not 100% what its called |
| Author: | Verm1n [ Wed Mar 30, 2011 1:20 am ] |
cheers for thats |
| Author: | Highway-Star [ Wed Mar 30, 2011 4:05 am ] |
tanshi wrote: its a place down near the cemitary, not 100% what its called
Ipswich Radiator Works |
| Author: | Verm1n [ Fri May 27, 2011 5:38 am ] |
Fity wrote: I got one from a LJ50 120y conversion if that fits.
did u find thats radiator FITY?? Brad |
| Author: | 2stroker [ Fri May 27, 2011 1:16 pm ] |
I have a custom triple core radiator that came out of an LJ with a Datsun engine, it as outlets on passenger side, thermo fan fitted and the bottom tank is even modified and cut out to clear a Sierra steering box in an LJ should you decide to go that way at some time in the future. $50 Brad I will get it out of the shed and take pic tommorrow |
| Author: | Verm1n [ Fri May 27, 2011 11:22 pm ] |
2stroker wrote: I have a custom triple core radiator that came out of an LJ with a Datsun engine, it as outlets on passenger side, thermo fan fitted and the bottom tank is even modified and cut out to clear a Sierra steering box in an LJ should you decide to go that way at some time in the future. $50
Brad I will get it out of the shed and take pic tommorrow cheers heaps for that im heading to norman park this avo to check out a car for a friend.. soo might swing by if u p.m an address Mob is 0419661732 Cheers Brad |
