https://auszookers.com/forum/
Grand Vitara Tension pulley
https://auszookers.com/forum/viewtopic.php?f=8&t=20961
Author:  GRANDBAZOOKA [ Wed Apr 13, 2011 5:55 am ]
Post subject:  Grand Vitara Tension pulley
Hi,after driving through a flooded road,just under a meter in depth,my car seems to be making a dry horrible noise. I have my suspicions it is the tensioner pulley bearings. How are these removed? and how much would it cost roughly?
Author:  steak_knife [ Wed Apr 13, 2011 6:12 am ]
Post subject:  Re: Grand Vitara Tension pulley
Check your alternator to........
idle bearing's are easy, but last time I looked into it, they were gen only...
Author:  GRANDBAZOOKA [ Wed Apr 13, 2011 6:22 am ]
I removed the alternator belt and started it,was still making the same horrible noise. It seems everything for a GV is genuine 8O . Any idea how much i'd be up for roughly?
Author:  steak_knife [ Wed Apr 13, 2011 6:26 am ]
No to price...
Could be the idler for the a/c p/s, just hope it's not the water pump......
Author:  GRANDBAZOOKA [ Wed Apr 13, 2011 6:33 am ]
Im not liking the sound of water pump! :( I hear they are a pain,so i have been told anyway.
Author:  steak_knife [ Wed Apr 13, 2011 6:37 am ]
Yep, just thought about it. cant be w/pump if the alt belt was off..
The idle for the a/c is quite low, so likely that's your noise, take the belt off O spin the idle, see if you can feel notchy yuk, then you've found it...
Author:  GRANDBAZOOKA [ Wed Apr 13, 2011 6:42 am ]
Ah thank god was dreading replacing the water pump. Ok i will check tomorrow and go from there.Thanks for your advice :)
Author:  steak_knife [ Wed Apr 13, 2011 6:44 am ]
Got nothing better to do..... :roll:
