It is currently Sun Jul 19, 2026 10:19 am
Post Posted: Fri Sep 02, 2011 3:30 am
Just put in a Check engine light on the Sierra (with G16B) so now i can check codes and its giving code 34 - MAF Signal Low.
So im after a 3 wire Air Flow sensor off a Vitara if anyone has one lying around.
Hopefully this will give the engine abit more balls.
Thanks, Josh
Post Posted: Fri Sep 02, 2011 4:42 am
Did you bother to test it?
The ECU is telling you it thinks the signal isnt right, could be a heap of things, jsut ask Stekky :)
Post Posted: Fri Sep 02, 2011 5:27 am
Yeah i tested it out. Getting 13.8V across the 2 outer supply terminals (with car running) and .4V on the signal wire regardless of weather it at idle or revving at about 4k. I read its ment to vary from about .5V to 5V.
Tested to signal wire from sensor plug to ECU plug. All good.
Also when the sensor is unplugged to motor revs say the same. I read that they should jump up with the senor out. Unless im missing something :blink:
Post Posted: Fri Sep 02, 2011 6:03 am
:roll: Tis got power...... :wink:
Post Posted: Fri Sep 02, 2011 7:01 am
What was wrong with yours Stekky?
Post Posted: Fri Sep 02, 2011 7:31 am
Mine was from here, was new not rebuilt though
http://www.rockauto.com/catalog/raframe ... de=1271506
Post Posted: Fri Sep 02, 2011 8:15 am
Some frucking idjet didn't have power to it... :roll:
Post Posted: Sat Sep 03, 2011 11:06 pm
Looks like im not going to get one cheap. :(
Post Posted: Tue Sep 13, 2011 11:38 pm
Got one coming from Ebay USA is off a Sidekick. $160 for a brand newie inc post. Hope its good quality.
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Wed Sep 14, 2011 8:27 am
mate i have one here.. if your interested.. i can post
Users browsing this forum: No registered users and 20 guests
