| WT: Vitara MAF Sensor https://auszookers.com/forum/viewtopic.php?f=8&t=25355 |
| Author: | zuk_244 [ Fri Sep 02, 2011 3:30 am ] |
| Post subject: | WT: Vitara MAF Sensor |
Just put in a Check engine light on the Sierra (with G16B) so now i can check codes and its giving code 34 - MAF Signal Low. So im after a 3 wire Air Flow sensor off a Vitara if anyone has one lying around. Hopefully this will give the engine abit more balls. Thanks, Josh |
| Author: | royce [ Fri Sep 02, 2011 4:42 am ] |
| Post subject: | Re: WT: Vitara MAF Sensor |
Did you bother to test it? The ECU is telling you it thinks the signal isnt right, could be a heap of things, jsut ask Stekky |
| Author: | zuk_244 [ Fri Sep 02, 2011 5:27 am ] |
Yeah i tested it out. Getting 13.8V across the 2 outer supply terminals (with car running) and .4V on the signal wire regardless of weather it at idle or revving at about 4k. I read its ment to vary from about .5V to 5V. Tested to signal wire from sensor plug to ECU plug. All good. Also when the sensor is unplugged to motor revs say the same. I read that they should jump up with the senor out. Unless im missing something
| Author: | steak_knife [ Fri Sep 02, 2011 6:03 am ] |
royce wrote: Did you bother to test it?
| Author: | zuk_244 [ Fri Sep 02, 2011 7:01 am ] |
What was wrong with yours Stekky? |
| Author: | royce [ Fri Sep 02, 2011 7:31 am ] |
Mine was from here, was new not rebuilt though http://www.rockauto.com/catalog/raframe ... de=1271506 |
| Author: | steak_knife [ Fri Sep 02, 2011 8:15 am ] |
zuk_244 wrote: What was wrong with yours Stekky?
Some frucking idjet didn't have power to it... |
| Author: | zuk_244 [ Sat Sep 03, 2011 11:06 pm ] |
Looks like im not going to get one cheap. |
| Author: | zuk_244 [ Tue Sep 13, 2011 11:38 pm ] |
Got one coming from Ebay USA is off a Sidekick. $160 for a brand newie inc post. Hope its good quality. |
| Author: | tonka_tuff [ Wed Sep 14, 2011 8:27 am ] |
mate i have one here.. if your interested.. i can post |
