After looking at a brake problem i've found that my rear bearings are quite noisy and have a bit of forward/back movement in them. I should be able to remove the axles & drum housing but just wanted to know if anyone has access to a press or something to remove the old bearings and push new ones on.
If someone could help me out it would be appreciated and if u let me know how you would like to be re-imbursed i should be able to arrange that too.
grind old bearings off but beeee careful not to damage shaft
u need a really long press just take it to suzistore and get them to do it prob cost u $50
I would go to suzistore but i've sent a PM off to weaves for some bearings which will prob save me a bit of $ over suzistore and i dont want them getting their panties in knot because i didn't buy my spares from them.
Hey man i got a press but i don't have a grinder to cut your old bearings off If you can get your old bearings off and bring your axles down one arvo ill press the new ones on for ya
Thanks Joe. I'm actually just considering taking in the axles to suzistore and getting them to supply and fit new bearings. I've just gotta give em a call and see what the damage will be first
Users browsing this forum: No registered users and 22 guests
