It is currently Sun Jul 19, 2026 2:25 am
Post Posted: Sat Oct 01, 2011 10:45 pm
Im after a Vitara ECU for a G16B MPFI, i want it for parts so if you have a stuffed one lying around ill take it.
Im after the Mitsubishi ECU with the yellow plugs.
Vehicle: yellow 83 sierra
Post Posted: Sat Oct 01, 2011 11:29 pm
hey mate i got a prefectly fine working one if you would rather a good one? it has the yellow plugs on the ecu
Post Posted: Sun Oct 02, 2011 4:22 am
Shedloads of other cars had ECU with the same connector.
If you are looking for a connector to make an adapter loom for aftermarket CPU you should consider this. I've bought plenty of stuff from them and I have had no worries. Support is good too.
Post Posted: Sun Oct 02, 2011 8:42 am
Ill let you know mate, im taking mine into work to replace the caps. If that doesnt work then ill be in the market for a new one.
Post Posted: Mon Oct 03, 2011 3:10 am
I wish, id love to put in a Mega Squirt system but the funds are needed elsewhere.
