It is currently Sat Jul 18, 2026 7:12 pm
Vehicle: MY2019 Jimny
Post Posted: Thu Nov 24, 2011 4:17 am
I need a 1m x 1m drain cover, preferably gal, in Penrith.
Pm me if you can help...
Linc
Post Posted: Thu Nov 24, 2011 4:47 am
Drain cover off side of the road ??
2''lift 31's twin locked & 6.5s
Vehicle: 1985 Holden Drover
Post Posted: Thu Nov 24, 2011 5:06 am
Find a sydney water site and unbolt it off the top of the well, plus they are staino ;)
1989 WT Sierra.
Post Posted: Fri Nov 25, 2011 5:14 am
I would rather not expose some poor bastard to a leg breaking fall if possible.
Post Posted: Fri Nov 25, 2011 5:38 am
Linc
Is this a standard item? Could you buy it from an industrial plumbing supply shop? Or does it need to be custom made? :?
Post Posted: Fri Nov 25, 2011 5:57 am
Standard is fine, and I know I can buy something new, but I am hoping that someone has some expanded mesh or something laying around that will do.
Post Posted: Fri Nov 25, 2011 2:01 pm
im more interested in why you suddenly have a big hole to cover up? lol
Post Posted: Fri Nov 25, 2011 8:39 pm
In the top right corner, you can se a drain that I raised the edges of.
It is surrounded by sleepers.
Vehicle: 4wd
Post Posted: Fri Nov 25, 2011 9:45 pm
Great bunch of guys you are :roll:
Watch out or you'll get sued.
Post Posted: Fri Nov 25, 2011 10:56 pm
i've seen some around that are made of polycarb or similar, which would be perfect for that kind of location and most likely a lot cheaper than steel... not sure if theyre filled with sand or something to keep them on the ground or not?
Post Posted: Sat Nov 26, 2011 12:15 am
Is it just a cover to hide the super secret location of your underground meth lab? :lol:
Post Posted: Sat Nov 26, 2011 12:30 am
If I told you it woudn't be much of a secret now, would it?
Post Posted: Sat Nov 26, 2011 3:31 am
Go down the scrap yard - Cheap as chips
Post Posted: Sat Nov 26, 2011 3:45 am
I did, he doesn't have one.
Vehicle: LJ20 LJ50
Post Posted: Sat Nov 26, 2011 4:29 am
If you raised the drain will it still work as a drain????
Camels have nice toes
Post Posted: Sat Nov 26, 2011 4:31 am
It is only an access point to the storm water.
Post Posted: Sat Nov 26, 2011 9:15 pm
mmmm Chips! :P
255 characters
Users browsing this forum: No registered users and 1 guest
