It is currently Sat Jul 18, 2026 6:26 pm
Post Posted: Fri Dec 02, 2011 2:33 am
Gday All, Got a zook and it needs to be modified... If anyone has anything on this list or can recomend somthing better (or a better combination of things) then please do.
Im even happy if you have a bussines or friends in the bussines who want to pedal me their wares.
Just putting it all down (without the wifes knowledge...)
2-3" spring set (possibly take a leaf out of the 3" to get them down to 2 inch and soften the ride a bit).
2" body lift kit
4.9 Transfer gears (or the whole case)
30-31" muddies on the appropriately offset rims (shocks are big, so might need a fair bit of offset)
Fast back soft top
Extended brake lines
Front seats
Checker plate internal pannels
Any help appreciated.
Cheers, Andrew
Post Posted: Fri Dec 02, 2011 2:36 am
you can get all that stuff from this site here.
http://www.lowrangeoffroad.com/
Post Posted: Fri Dec 02, 2011 2:38 am
Bodylift : http://auszookers.com/index.php?name=Fo ... ic&t=15518
Suspension: http://auszookers.com/index.php?name=Fo ... ic&t=20219
Post Posted: Fri Dec 02, 2011 2:51 am
put a locker in it and it will make it go heaps more place's
if u drive a loud toyota ute u drink rum
Post Posted: Fri Dec 02, 2011 2:53 am
just got a locker and a set of rancho RS9000's - back ranchos in atm, locker to go in this weekend along with the front ranchos... One problem ive found so far is because the shocks are sooo much thicker than the standard, it only has a mm or 2 gap between the rear brake line clip/attatchment point on the rear diff and ive found a small dent in the shock already... anyone know the correct fix?
Post Posted: Fri Dec 02, 2011 3:06 am
What i did was cut the bottom bit of the mounting bracket, then fold the bracket over onto the top of the diff and tack weld it on.
This way you brake lines stay where they are but the brackets are moved
Post Posted: Fri Dec 02, 2011 6:19 am
got some checkerplate panels for in the back, holes cut for 4 inch speakers
