Page 1 of 1
[ 8 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5935 Location: Northcliffe, W.A.
 Posted: Sun Dec 18, 2011 2:32 pm |
I'm after....
An LJ80-1 front panel, as in non-Stockman. I want the metal panel, not the plastic grill. The panel on mine is all cracked and the grill is fine, how backwards is that?!
LJ50 transfer case, 3:1 low, 1.7:1 high.
LJ81 windscreen rubber.
LJ80 door mirror, just need the mirror, not the arm bit.
I'l Add more when I think of/find it.
Thanks
Hayden
masterA
Joined: Tue Jan 18, 2011 3:24 am Posts: 976 Location: Perth
 Posted: Sun Dec 18, 2011 11:02 pm |
I've seen a couple of LJ's at SuziStore sitting at the front....may pay to give them a call
_________________ Fast,Cheap,Reliable-Pick 2 & 3rd is laughable
3cyl
Joined: Tue Jan 29, 2008 10:30 pm Posts: 2054 Location: Ipswich
 Posted: Mon Dec 19, 2011 8:03 am |
If you can salvage the radiator support (inner) panel you can reskin the front panel, that's what I ended up doing.
_________________ awesome only comes in 2 colours, camo & bare metal
sideways
 Posted: Wed Dec 21, 2011 5:56 pm |
masterA wrote: I've seen a couple of LJ's at SuziStore sitting at the front....may pay to give them a call  Thanks, will do. 3cyl wrote: If you can salvage the radiator support (inner) panel you can reskin the front panel, that's what I ended up doing.
Both the inner and the outer panel are cracked, the inner probably repairable so but the outer is a bit bent and rusty too. Still need the outer bit for that, I've only got crappy Stockman panels and they're completely different.
I don't mind if someone in the eastern states has one and wants to post it over.
Got some universal windscreen rubber.
Cayden
Joined: Wed Nov 30, 2011 12:57 am Posts: 90 Location: Wynyard /Tasmania
Vehicle: Suzuki Jimny
 Posted: Fri Dec 23, 2011 10:35 pm |
I can get the mirror
_________________ Any 4wding
Highway-Star
Joined: Thu Apr 30, 2009 11:30 pm Posts: 4109 Location: Ipswich
 Posted: Sat Dec 24, 2011 6:43 am |
sideways wrote: masterA wrote: I've seen a couple of LJ's at SuziStore sitting at the front....may pay to give them a call  Thanks, will do. 3cyl wrote: If you can salvage the radiator support (inner) panel you can reskin the front panel, that's what I ended up doing. Both the inner and the outer panel are cracked, the inner probably repairable so but the outer is a bit bent and rusty too. Still need the outer bit for that, I've only got crappy Stockman panels and they're completely different. I don't mind if someone in the eastern states has one and wants to post it over. Got some universal windscreen rubber.
I'll swap you!  I got a really awesome one which my father is happy to use, but yours will save him tonnes of work!
_________________ Clearance Hole Technology
sideways
 Posted: Tue Dec 27, 2011 6:18 pm |
Cayden wrote: I can get the mirror I'l send you a PM in approximately 4 hours! Highway-Star wrote: sideways wrote: masterA wrote: I've seen a couple of LJ's at SuziStore sitting at the front....may pay to give them a call  Thanks, will do. 3cyl wrote: If you can salvage the radiator support (inner) panel you can reskin the front panel, that's what I ended up doing. Both the inner and the outer panel are cracked, the inner probably repairable so but the outer is a bit bent and rusty too. Still need the outer bit for that, I've only got crappy Stockman panels and they're completely different. I don't mind if someone in the eastern states has one and wants to post it over. Got some universal windscreen rubber.  I'll swap you!  I got a really awesome one which my father is happy to use, but yours will save him tonnes of work!
Okay!  Got pics? Mine comes pre-bent.
Mine has a Corolla radiator in it and I can't tell if it's been chopped or not to fit it in(I don't think it has, but it's been very nicely done) , so it may be a bit of a pain for you to use? I'l grab some pics when I pull it out.
Thanks
Hayden
Highway-Star
 Posted: Wed Dec 28, 2011 7:38 am |
sideways wrote: Highway-Star wrote: sideways wrote: masterA wrote: I've seen a couple of LJ's at SuziStore sitting at the front....may pay to give them a call  Thanks, will do. 3cyl wrote: If you can salvage the radiator support (inner) panel you can reskin the front panel, that's what I ended up doing. Both the inner and the outer panel are cracked, the inner probably repairable so but the outer is a bit bent and rusty too. Still need the outer bit for that, I've only got crappy Stockman panels and they're completely different. I don't mind if someone in the eastern states has one and wants to post it over. Got some universal windscreen rubber.  I'll swap you!  I got a really awesome one which my father is happy to use, but yours will save him tonnes of work!  Okay!  Got pics? Mine comes pre-bent. Mine has a Corolla radiator in it and I can't tell if it's been chopped or not to fit it in(I don't think it has, but it's been very nicely done) , so it may be a bit of a pain for you to use? I'l grab some pics when I pull it out. Thanks Hayden
I was being a bit sarcastic with the "awesome" bit.... I just think your front panel looks pretty good. Anyway I'll try to get some photos later in the week if you want (feel free to PM or email me if I forget)... best way I can describe the panel is concave...
Page 1 of 1
[ 8 posts ] |
Users browsing this forum: No registered users and 86 guests
