It is currently Sat Jul 18, 2026 10:27 am
Post Posted: Mon Jan 16, 2012 12:45 am
Item needed:
Output shaft from 1.3L transfer case.
Problem:
on the front of the output shaft there is a circlip ring - the end of the shaft as copped some abuse and the circlip will no longer hold the gearset on.
Looking for someone that has one laying around, prefer not to buy a full case.
PM on here or sms 0408293381.
Brendan
Vehicle: 4wd
Post Posted: Mon Jan 16, 2012 9:24 am
I have one here :)
PM me if you still need one.
Watch out or you'll get sued.
Post Posted: Mon Jan 16, 2012 8:22 pm
Thanks Stockman - is this the shaft you were thinking?
Vehicle: 4wd
Post Posted: Tue Jan 17, 2012 3:48 am
Yes, the stock version of that.
Post Posted: Fri Jan 20, 2012 3:35 am
Anyone else with one, unfortunately Stockman only had the front output shaft.
Really dont want to spend another $250 getting one from Lowrange.
Please help!
Post Posted: Fri Jan 20, 2012 9:42 am
Ive got a stuffed transfer case with chewed out gears. Ill open it up over the weekend and make sure the shaft is good and let you know.
Post Posted: Fri Jan 20, 2012 11:34 am
That would be awesome, appreciate it
Post Posted: Sun Jan 22, 2012 3:46 am
Got the case apart, ive got the shaft you were after but its worn abit on the low range side of the selector spline.
Send me a pm if you still want it.
Close up of the shaft.
Now ive got the case apart ill throw in any other bits you need to.
Post Posted: Sun Jan 22, 2012 10:42 am
Awesome, check your pm inbox :)
Users browsing this forum: No registered users and 24 guests
