It is currently Sat Jul 18, 2026 10:26 am
Post Posted: Tue Jan 17, 2012 3:31 am
I bought some transfer gears about 8 or 9 months ago for a rainy day. It is currently raining :helloo: .
So I am after a 1.3 Sierra transfer case to put them in (not coily). Don't need flanges etc. Don't care if it has bad bearings. Must have good case, and the gear set does reuse some gears, so no stripped teeth please. Would like a lever with it also :)
I'm near Ipswich QLD, so would prefer someone in the SEQ area. Post here or PM me if you can help :helloo:
edit: I actually want 2. So if you happen to have 2 you'd like to part with, let me know :D
Thanks!
Clearance Hole Technology :P
Post Posted: Tue Jan 17, 2012 9:30 am
I mite have one mate depends if that guy with the reducted transfer will sell it cheap enough.
Post Posted: Wed Jan 18, 2012 3:09 am
Cool. Let me know when you can.
Cheers.
Post Posted: Fri Jan 20, 2012 7:30 pm
Looks like I have 1 lined up :)
Anyone got another? I don't want to have to buy another Sierra just for a TC :helloo:
Post Posted: Fri Jan 20, 2012 9:46 pm
What parts do you need from the case? Ive got one with stuffed gears that im going to pull apart tomorrow. If its just the case etc that your after it shouldnt be too bad to post.
Post Posted: Fri Jan 20, 2012 10:06 pm
I need the main shaft, and one of the gears (for 4.9 gear set). A complete case would be preferable. Not sure how much that would cost to post though :? .
Vehicle: 2018 DMAX
Post Posted: Fri Jan 20, 2012 10:49 pm
Ive got my broken case sitting here dude. Gears in it are still good, one bad bearing, partially dismantled.(shifter house is off). Also have all the bits left over from building a 6.5 case...
Post Posted: Fri Jan 20, 2012 11:06 pm
Well mine wont be much good to you. Im looking at giving the main (rear output) shaft to Brenno and my gears are missing more teeth then a redneck stereo type! :D
Post Posted: Fri Jan 20, 2012 11:38 pm
Cheers Jamie. I'll get back to you. I'm tossing up buying a perfectly good Widetrack for $1500 and stripping it.
No worriesZuk-244, thanks for the offer though! :)
Users browsing this forum: No registered users and 26 guests
