It is currently Tue Oct 06, 2026 2:14 am
Post Posted: Thu Apr 12, 2012 4:24 pm
looking for the shaft that the speedo cable bolts into on the transfer case..
1.0 switch type or w/t case..
anyone got a broken t,case for parts?? or know where to buy this part new??
brisbane.
Vehicle: LJ50V, SJ70
Post Posted: Fri Apr 13, 2012 12:06 am
ROAR99 wrote:
...1.0 switch type or w/t case..
Which case? The two ratios in the 2 versions switched cases have their own specific driven gears.
See THIS THREAD
"On transfer cases where the Hi ratio is 1.409 to 1 and Lo is 2.268 to 1 (All 1.3lt Leafies), the drive gear has 7 teeth and the driven has 20 (2.85:1).
On cases with Hi=1.580/ Lo=2.511 (1.0lt w/switch), the teeth are 4 and 12 (3:1)."
If you have a 1.0 w/switch case (SJ40 or Maruti), the Suzuki Genuine Part number is 29421-80050.
If you have a 1.3 case (NT or WT), the part number is 29421-80451.
Post Posted: Fri Apr 13, 2012 1:15 pm
thanks 303zuke for the part no. & info..
## its a 1ltr case ## rebuild kit is the same as 1.3 so i assumed that part would be the same too.
