It is currently Wed Oct 07, 2026 1:17 am
Post Posted: Wed Apr 25, 2012 1:50 pm
Hi all - I need - Desperately - A head for a 1992 Vitara (16B EFI) 1.6lt engine. PLEASE PM if you can help me out here.
Cheers - Tony
Post Posted: Wed Apr 25, 2012 4:25 pm
Good G16B heads are VERY rare Tony.
Most people, myself included, hold out looking and then end up buying a brand spanker for $550.
Post Posted: Wed Apr 25, 2012 4:29 pm
What was your bad run Jas?? 2 or 3 wasn't it :cry:
Post Posted: Wed Apr 25, 2012 6:48 pm
Yes, $550 for a new, bare head. Not worth looking for second hand IMO.
Post Posted: Wed Apr 25, 2012 7:54 pm
Yep 3 :evil:
Post Posted: Thu Apr 26, 2012 8:19 am
OK - Can anyone tell me if the Carby head and the EFI head are the same?
Post Posted: Thu Apr 26, 2012 8:43 am
16A Carby is 8 valve.
16B EFI is 16 valve.
Heads and both manifolds are different.
You can fit an A head to a B block and visa versa but you will need to fit the corresponding pistons.
Post Posted: Thu Apr 26, 2012 8:55 am
You can fit an 8v head to a 16v bottom end without changing pistons, but a 16v head on 8v block needs a piston swap.
Not sure why you would want a carby and 8v head if you already have a 16v though :?
Post Posted: Thu Apr 26, 2012 10:01 am
Thanks Guy's I have an engine (16B) with no head - The cam etc is there but no head - Tony
Post Posted: Thu Apr 26, 2012 11:37 am
If you end up buying a new head and need valves, springs etc yell out as I still have one of my many cracked heads here as a doorstop.
Post Posted: Thu Apr 26, 2012 12:18 pm
Thanks Jas - I will keep that in mind
Vehicle: 93 vitara estate
Post Posted: Thu Apr 26, 2012 9:02 pm
yep...........
im in the same boat tony, 93 vitara cracked head
just bought a 2nd hand from wreckers, went to get it shaved and turns out its already warped(been overheated at some stage)
lucky the wreckers are going to take it back and said they have another one there so ill be trying again but if not im just gonna buy a new one :peaceout:
Post Posted: Fri Apr 27, 2012 11:00 am
maybe look out for a baleno being wrecked. i have picked up whole engines for not much more than $550
Post Posted: Fri Apr 27, 2012 11:46 am
Unfortunately Tanshi the nearest wrecker to here is a long way away :cry:
Post Posted: Fri Apr 27, 2012 12:12 pm
Will this bolt in? or is there heaps of shit to change?
http://www.ebay.com.au/itm/suzuki-balin ... 500wt_1202
Tony
Users browsing this forum: No registered users and 36 guests
