It is currently Mon Jul 06, 2026 1:07 pm
Post Posted: Mon May 14, 2012 10:42 am
OK, im needing to "borrow" some ones vitara for a couple of hours. Jrzook being the smart cookie he is, is going to run some tests to see what signals the ECU from the 1.6 sends to the TCM for the AW4 auto. basically we just need to plug some probes into your wiring and see what signals come out. Happy to buy you a carton for your time.
PM me if you can help us out.
Post Posted: Mon May 14, 2012 6:05 pm
*In Brisbane
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: '96 LWB trayback
Post Posted: Mon May 14, 2012 6:30 pm
Willing to help with beer. Surely we have a thirsty vitara auto owner out there
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Tue May 15, 2012 12:39 pm
If no one else comes fourth I should have mine registered next week.
We are amphibious
Post Posted: Tue May 15, 2012 1:27 pm
ahh there we go, we have a winner!!!!
Post Posted: Fri May 18, 2012 6:47 am
Are you sure that it is an AW4 and not an AW03 as described here:
http://www.rhinoman.org/manuals/AW03_TCM/aw03.pdf
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Fri May 18, 2012 10:25 am
That'd be an overseas variant no? Being a Suziki Sidekick.
Post Posted: Fri May 18, 2012 5:25 pm
The Sidekick is the US model but the TCM seems to have been used worldwide.
1986 Suzuki SJ413K
Post Posted: Mon May 21, 2012 8:43 am
its the vitara one from here that were after. 4 speed auto. It gets called the AW4 but its not littlerally that number.
also chasing the TCM plug for one
Post Posted: Mon May 21, 2012 10:03 am
AW4 = Asian Warner 4sp. Its not neccessarily the model number.
Post Posted: Mon May 21, 2012 11:29 am
Correct.
Though the model number for the JEEPs that used them was actually AW4 which i think is where it came from
Post Posted: Tue May 22, 2012 2:52 am
Yeah, I spent loads of time searching for AW4 information and didn't find anything that properly matched the Zuk TCM.
If you only need a test connector then you can use a 26-pin connector from a 16V Vit ECU as long as you slice off the two outer polarization keys. The terminals are easy enough to remove if you need to swap their positions.
1986 Suzuki SJ413K
Post Posted: Tue May 22, 2012 10:28 am
Really? I think I have a spare ECU plug in my ECU pile. Ill check it out!
James do you know if the firmware for the ECUs that came out in the manual vitaras support the auto TCM? There are output pins on the ECU socket but the plug just hasn't been populated.
Dan
Lil Foot!
Post Posted: Tue May 22, 2012 11:22 am
right, that will give me another source for a plug if i can find one in a wrecker.
i have one that almost fits from my j20 wiring loom, so i guess they are similar
Post Posted: Tue May 22, 2012 5:09 pm
Which ECU have you got? I'd have to have a look back through my notes but I don't think the 16V manual ECUs have the auto functions in the firmware, they don't usually have the components populated on the PCB but thats not to hard a retrofit.
The same ECU plugs were also used on Mazdas, Subarus and a few other Japanese cars as well as a bunch of other Zuks so you should be able to source one at a breakers easily enough.
1986 Suzuki SJ413K
Post Posted: Sun Jun 10, 2012 7:16 pm
Did you have any luck developing this ? I'm buying an AW4 for my zook in the hope that one of you smart cookies develop a way to make the AW4 work as stand alone or with an aftermarket computer (namely my haltech E6K).
I won't be able to use this auto until i (or someone else) figures this out
Post Posted: Sun Jun 17, 2012 7:46 pm
Dans (jrzook) all over it. fingers crossed it works
Users browsing this forum: No registered users and 62 guests
