It is currently Fri Jul 17, 2026 6:44 pm
Vehicle: bj70 landcruiser
Post Posted: Wed Jul 04, 2012 11:20 am
Hi looking for a z link to suit my spoa wt Sierra, I will be buying I a high steer kit from rocky road in the states but just need some thing to get it running until I can afford the high steer
I'm located in revesby nsw 2213
Contact Tim 0432361819
Thanks
Post Posted: Wed Jul 04, 2012 11:57 am
Please dont put other road users at risk because you can't afford the proper gear......
Post Posted: Wed Jul 04, 2012 12:22 pm
Try lowrange also.
Post Posted: Wed Jul 04, 2012 12:23 pm
1- How is it putting other road user at risk? A correctly made z link should not be dangerous it may cause some bump steer but how is it more dangerous than than a high steer kit which bolts to the brake caliper mounts?
2- I never said I drive it on the road
3- thanks for helping me find the part I need (hence why I posted in the "I want it thread"
Post Posted: Wed Jul 04, 2012 12:50 pm
z link puts weak points in the bends. A stock straight draglink bends offroad. A zlink will be worse. Also depends on material etc.etc
Welding to a steering arm is a no no
If its just a trail rig, bodge away no problems.
Build it right first.
Post Posted: Wed Jul 04, 2012 1:15 pm
Qn 1: Do you drive it on the road?
if yes, stop being a douche and get a highsteer kit.
If no, then bend your original draglink to suit your needs.
Post Posted: Wed Jul 04, 2012 1:45 pm
Ok so like I said z link made from correct material and bent properly (not heated) should be fine for offroad until funds allow a high steer kit so (brenno) you don't have to shoot me down due to your assumptions, asking questions never hurt anyone, now can i find the parts I need
Bluesuzy- thank you for the input what are your thoughts between the sky high steer from Lowrange and rocky roads kit?
Post Posted: Wed Jul 04, 2012 1:54 pm
Also brenno do you really think bending a stock drag link which everyone knows bend off road when They are straight is a sensible idea? Never mind the fact that I like being able to turn left? Just asking mate let me know what you think?
Thanks
Tim
Post Posted: Wed Jul 04, 2012 7:10 pm
:lol:
Post Posted: Thu Jul 05, 2012 3:05 am
If your stick and need one mate I might be able to make something. Just have to work out what ends to use. By truck weighs in at 2.5 tone loaded and runs a drag link with multiple bends in it and running 35s with flipped rims. It has never bent at all and it's modd played as well
Your rims flipped from $50
Post Posted: Thu Jul 05, 2012 3:06 am
And like said if you use the right steel it will work mines 35mm 1045 solid bar.
Post Posted: Thu Jul 05, 2012 8:26 am
:rofl: You wish the old Massey was that light!
Post Posted: Thu Jul 05, 2012 8:56 am
It went over the scales at 2.2 last time and I havnt done much more
Users browsing this forum: No registered users and 31 guests
