It is currently Fri Jul 17, 2026 6:01 am
Post Posted: Thu Oct 11, 2012 5:41 pm
Need a pair of WT diffs for KT. Ideally with 4.1 gearing, but 3.7 is ok too. PM or 0434 769 815 if you can help
Vehicle: Getting parts atm
Post Posted: Thu Oct 11, 2012 5:48 pm
Seen a set on gumtree, had disc rear end...
Post Posted: Thu Oct 11, 2012 6:09 pm
Just found that ad, bit rich for my blood atm, thanks for putting it up tho :D
http://www.gumtree.com.au/s-ad/kurri-ku ... 1007784434
Post Posted: Fri Oct 12, 2012 6:29 am
SOA too so would need more work than it first appears.
Vehicle: 91 Sierra
Post Posted: Fri Oct 12, 2012 7:56 am
I might be able to help. I still have these sitting down the bottom shed.
A set of WT axles wheel stud to wheel stud, came of an 89 model, pulled apart to weld a set of TSOR perches at NT spacing which was done by the man himself on his jig in the Fatcave, deconstruction process was numbered and bagged to help me rebuild, new axle seals and hand brake cable as shown included.
Things you should know - one of the front bearings had collapsed, check the last 3 pictures for more detail on this hub issue, and the front diff has a dent which doesn't affect operation. I suspect though, from the standard of your ute you would have to address this. Pull diff out and tap out from the inside maybe ??
i'm chasing $375;
Images of collapsed bearing / stub, before i pulled it all apart;
Users browsing this forum: No registered users and 18 guests
