| FOUND - THREAD CAN DIE https://auszookers.com/forum/viewtopic.php?f=8&t=37732 |
| Author: | DarkHorse [ Fri Dec 14, 2012 1:01 am ] |
| Post subject: | FOUND - THREAD CAN DIE |
Hey all, I need a couple of bits for the new bus that are damaged beyond reasonable use... I need: - Fuel Tank (any SV one will do) - Gearbox crossmember (LWB manual if it makes any difference.) Cheers! |
| Author: | DarkHorse [ Sat Dec 15, 2012 3:38 pm ] |
| Post subject: | Re: SV620 tank and crossmember |
No-one got either? |
| Author: | matty_wall [ Sat Dec 15, 2012 4:06 pm ] |
There is an LWB SV at the wreckers near windsor on the northern road. |
| Author: | DarkHorse [ Sun Dec 16, 2012 9:15 am ] |
Thanks mate, will check it out. |
| Author: | DarkHorse [ Fri Dec 21, 2012 11:13 am ] |
Also chasing a handful of the plastic clips that hold the flares on to the body. I know Ripco stock similar, but they never seem to work as well... |
| Author: | Joe [ Fri Dec 21, 2012 2:57 pm ] |
Hey Darky if ya get really stuck for a tank Suzistore have a SV620 out the back, i'm not sure if it's dent free or even if it has a tank in it but it might be worth a try |
| Author: | DarkHorse [ Fri Dec 21, 2012 3:13 pm ] |
Thanks mate. Wreckers over here have a couple of SVs, apparently one has a good tank, the other a good crossmember, so I'll suss them out tomorrow. |
