It is currently Thu Jul 16, 2026 9:05 am
Vehicle: Suzuki Sierra
Post Posted: Fri Jan 11, 2013 11:57 am
I'm at the stage in my build where I have to start looking for various parts that I will need to finish my project and have it ready for a roadworthy.
The parts that I will need are:
Indicator assembly
The part that joins the handbrake to the handbrake cable
Both side door mirrors
The lower engine pulley, the one visible. Mine got warped some how
Chances are I won't be able to pick items up unless they are quite close by because I rely on other peoples transportation at the moment... So if items can be posted that would be a great help! :)
Ill probably be adding more items
Post Posted: Fri Jan 11, 2013 3:50 pm
pointless fact.. you don't legally have to have a mirror on each door.. aslong as you have a drivers side and a reversing one, you don't have to have the passenger side..
I'll have a look..
I think I have 2 mirrors, handbrake assembly *assuming its to the transfer case not to rear diff 'WT'*, pulley*assuming it is a 1.3carby*
do you want front, side or rear indicator assembly??
'would have find though'
Located Redbank plains
Post Posted: Fri Jan 11, 2013 4:56 pm
Its a wide track 1.3L carby engine, and when i say handbrake assembly thing, i have all the cables apart from the bit that connects the actual cable to the handbrake itself, its the part that lets me adjust it if i need to i think...
and by indicator assembly, i meant the bit that sits behind the steering wheel that allows me to turn on and off wipers and inicators and all.
Sorry for the dodgy information, not particularly with it today for some reason :? :roll:
Post Posted: Fri Jan 11, 2013 7:24 pm
I got about a billion NT handbrake setups.. gave away the last wt handbrake stuff I had..
I also got about a billion indicator lights but no dash cluster... haha
Post Posted: Sat Jan 12, 2013 1:36 pm
This is the connect for the handbrake I am chasing :) I figured a pic would give more information than my own dodgy information :lol:
