SierraDan wrote:
Haha, there is a website with all that sort of crap on it. Gus would remember what its called.
can't find the 710 caps but i did find this ripper
http://kalecoauto.com/index.php?main_pa ... ucts_id=31Seasonal Tire Air $28.90
Everyone knows that temperature can have a great impact in your tire pressure. This is why you absolutely should use the correct air for your tires! For example, your car should usually have the tires set to 32psi. If you are using summer air in the summer, this is fine. However! If you use this summer air in the dead of winter, your may actually only be running at about 22psi! Each can will do one average sized tire. Sold in sets of 1 each.
