It is currently Thu Jul 16, 2026 1:32 am
Post Posted: Fri Apr 12, 2013 8:35 am
My Nephews are now officially Sierra owners :woohoo:
They have a bit of work to do before roadworthy inspection and need some parts
Stuff needed:
- Slide tracks on the side of the B pillar that the soft top slides on to Thanks mrw82
- Roof bow that holds up the rear of soft top, and mounting hardware
- A soft top, will consider anything that's intact
- Rear seat, prefer mid 90's trim but consider any
- Bonnet rest (the sticky outy bits at the top of the windscreen frame Thanks mrw82
- Rubber strips that fit between the body and WT flares
Edit:
also need
- Head light bulb holders or complete headlights.
- drain plugs for footwells
Post Posted: Fri Apr 12, 2013 9:15 am
Stuff needed:
- Bonnet rest (the sticky outy bits at the top of the windcreen frame
I can help with these paul. swap you for a sticker.
The flare rubber try Clark rubber.
Post Posted: Fri Apr 12, 2013 9:34 am
^^ Done, cheers
