It is currently Wed Jul 15, 2026 7:33 pm
Vehicle: 92 softop w/GTi motor
Post Posted: Sun May 05, 2013 6:28 pm
Hey guys,
Anyone have a 4 pin sierra diff carrier laying around?or a complete stuffed centre?
I believe I need one to fit my spartan locker in the front.
Sydney/newie/central coast region would be great.
cheers
Post Posted: Mon May 06, 2013 7:59 pm
bump,still in need of this fairly urgently,
Post Posted: Tue May 07, 2013 10:36 am
Spartan locker will fit a 2 pin housing, but needs the cross pin support block from the Sierra 4 pins.
If your front diff isn't something unique.
I have a Spartan in my 2 pin Vitara front diff, using the pin block from a sierra.
Vehicle: 1985 lwb sierra UTE
Post Posted: Tue May 07, 2013 11:45 am
i have a wt rear
Post Posted: Tue May 07, 2013 11:54 am
I should have been clearer,low range call it a single pin and four pin.
My front housing only has 1 pin through it with 2 spider gears only so I need the rear carrier(has a second pair of holes drilled in it for the 2 short shafts)and a pinion support block.
Post Posted: Tue May 07, 2013 11:55 am
Keensy85 thanks for the offer ill keep it in mind if I can't find one locally.
Post Posted: Tue May 07, 2013 12:00 pm
My Vitara only has 1 pin, also, just a terminology thing.
a 4 Pinion will be a stronger, better option, but is not essential.
My Front Spartan has been working well for over a year, now.
Post Posted: Tue May 07, 2013 3:33 pm
So basically I use the long pin only and use the 4pin pinion support block as a spacer/bush between the 2 lock plates?
Post Posted: Tue May 07, 2013 4:00 pm
That is what I did, yes.
Though I still think grabbing a 4 pin is a good idea if you can.
Post Posted: Tue May 07, 2013 4:04 pm
Thanks for the advice mate....ill keep it in mind,need to get something sorted before the weekend so I'm starting to get desperate now.
Post Posted: Tue May 07, 2013 8:24 pm
If I get stuck u can have mine just pay for postage I would say a six pack but the beer would get cold lol
Post Posted: Tue May 07, 2013 8:56 pm
Keensy is it complete centre or just carrier?
I don't need the pinion/housing bearings or ring gear just the centre carrier.
Post Posted: Wed May 08, 2013 7:48 pm
At the moment it's complete ... It had stuffed bearings but I can strip it all down for u
Post Posted: Wed May 08, 2013 8:09 pm
your a legend mate,ill give it to friday for one to come up locally (still got a wrecker or two to try) if i can't i'm more than happy to pay for postage and sling you a few bucks for it.
cheers man
Post Posted: Thu May 09, 2013 7:12 pm
Still desperately want one before weekend,will travel to pick up.
if not ill sling you some cash on monday keensy
Users browsing this forum: Google Adsense [Bot] and 43 guests
