It is currently Wed Jul 15, 2026 12:31 pm
Post Posted: Thu Jul 11, 2013 7:39 am
Hi guys, I'm chasing some adjustable panhard rods and steering dampener to suit my jimny. I'm in Brisbane but happy to drive or pay postage. Thanks in advance, Lisa
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jul 25, 2013 2:50 pm
panhard in au http://www.outdoorauto4x4.com/b/22763/1 ... jimny.html
panhard uk http://www.jimnybits.co.uk/shop/jimny/s ... od_23.html
dampner in uk http://www.jimnybits.co.uk/shop/jimny/s ... rod_8.html
the pan hard only suits greater than 40 mm lift
if death wobble (steering shimmy) is the reason you want a steering dampener be warned, it wont work
your best off with shiming the king pins, and if they need replacing replace the king pins, and since you already have everything pulled apart do scraper seals and regrease/ replace the main wheel bearing, as the original ones don't last long.
http://www.jimnybits.co.uk/shop/jimny/s ... _1090.html to stop the wobble,
http://www.jimnybits.co.uk/shop/jimny/s ... d_467.html and http://www.jimnybits.co.uk/shop/jimny/s ... rod_6.html while your there cos their cheap compare to the time involved pulling the whole thing apart, and shimming the bearings causes additional wear so may as well get as long as possible and keep the old ones as a spare set. http://www.jimnybits.co.uk/shop/jimny/s ... d_622.html for main wheel bearing if its had a rough life. they dont live that long if they get water in them
^ king pin bearings, pins should be ok
Post Posted: Sat Jul 27, 2013 6:59 pm
Thanks heaps for the above info, much appreciated
Users browsing this forum: No registered users and 21 guests
