It is currently Wed Jul 15, 2026 7:27 am
Post Posted: Mon Jul 15, 2013 5:07 pm
Wanted Complete sierra power steering setup.
extended Shackles,
f100 rims, or cut and flipped rims.
For NT sierra,
Located in Darwin but happy to pay post.
Post Posted: Mon Jul 15, 2013 5:31 pm
If you want new shackles, send me a PM and I'll sort you out.
For the power steer, just grab the steering box, lines, resevoir and pump from any 1.6L vitara, and buy one of these >>>
BenT wrote:
Sierra to Vitara Power Steering Kit
This bolt on kit is designed to fit Suzuki Vitara / Escudo power steering to a RHD (right hand drive) Sierra or Samurai using a machined wedge to align the steering box with the steering column.
The box is mounted as far forward as possible (+20mm) to give room to move the axle forward without the steering drag link and tie rod rubbing on each other. Great for RUF spring conversions or when moving the front axle forwards to fit bigger tyres.
The kit includes:
CAD designed, CNC machined wedge adaptor
Laser cut pump adaptor bracket to mount the Vitara power steering pump to the block
Spacer to move the radiator mounting bracket to clear the steering box.
All required high tensile fasteners
Installation instructions
You just need to get the following parts from a Vitara:
Power steering box with pitman arm
Power steering pump
Factory power steering pump mounting bracket
Hoses and reservoir.
Installation also requires a collapsible steering shaft, (found on later model Sierras / Samurais), or shortening of the stock steering shaft, plus multi-rib pulleys from a 1600 Vitara motor (or a 1600 engine conversion! - see my other kits)
Price is $220 AU + $30 AU shipping.
Wedge and bolts only is $160 AU + $20 AU *
*Note: Wedge only option is intended for people who have cut the radiator mount off the chassis on the left side. Even with a 1.6, the stock pump position is low down and the pulley will hit the radiator mount on the chassis, so the full kit with pump relocation bracket is often needed.
Vehicle: sj51
Post Posted: Mon Jul 15, 2013 5:54 pm
or grab a jimny power steering setup, if you buy it from the uk you will get it for a fraction of the cost of them here ;)
Post Posted: Mon Jul 15, 2013 7:42 pm
extended Shackles,
For NT sierra,
My brother should have a power steering adaptor kit, pump and steering box and a set of new extended shackles.
Ill talk to him and see if he still has everything. He lives in Gladstone, so postage shouldn't be too bad.
Post Posted: Tue Jul 16, 2013 1:24 pm
Ridge wrote:
extended Shackles,
For NT sierra,
Cheers Mate.
